- Jan 20, 2026
- 59
- 150
- 2025 F250 Tremor Lariat Ultimate, 6.7 HO, Antimatter Blue
- Toyotas Lots of them
Planning my suspension upgrades after I pull off the Ranch hand big ol piece of steel bumper on my 2025.
Looking at this BDS 2" kit
shocks, springs, track bar mount.
and potentially adding a set of RA drop brackets, Maybe a 1" bottom coil spacer to get rid of the rake which I despise.
My question is are the drop bracket to be uses in conjunction with the OEM caster shims or the the replacement ones in the BDS package since I may be going into that 3" lift territory?
A quick google search brought this up:
Yes, radius arm drop brackets or caster shims are highly recommended—often necessary— to correct caster loss, prevent "flighty" steering, and avoid potential death wobble. For lifts 2–3 inches and higher, drop brackets are preferred to restore proper geometry, while shims can be used for smaller lifts or as a cheaper alternative.
Key Considerations from Forums & Experts:
- Why You Need Them: Lifting the front end reduces caster, causing the truck to wander and feel unstable.
- Radius Arm Drop Brackets: Generally considered the better, more complete solution for 2.5"+ lifts to fix caster and restore factory ride quality.
- Caster Shims: A viable option for smaller leveling kits (1.5"–2"), but can be difficult to install and sometimes less effective than brackets for larger lifts.
- Other Recommended Upgrades: Along with caster correction, a track bar relocation bracket or an adjustable track bar is often recommended to re-center the axle.
