Clicking clacking over small bumps at low speed
Tumbler
Mytremor22
22 tremor lariat
Hi all,
So I’m having an issue with clicking and clacking at low speeds, have had all the shocks replaced under warranty at45000om, at 49000 now and it’s happening again, anyone else have this issue, looking to get the shocks looked at again, or is it something else maybe. I’ve read elsewhere that there is an issue with the tremor shocks.
Hi all,
There are numerous discussions on shocks in here, search for "shocks" and you'll see many have changed them out. In some cases, people have replaced the OEM shocks more than once. A post recently said they also have noise in their 24. It wouldn't hurt to have the manuf. look at them again, or replace them with a quality shock from Bilstein, Fox, King, etc.
A few others have had issues with them on here. Searching you find a wide range of opinions from just replace again up to replace with carli e-venture suspension.
I was getting a similar sound and it was one of my hubs, try rotating them from auto to lock then back, see if that helps. One of mine is stuck, I rotated it with a pair of pliers a few times and the sound is gone.
Hi all,
OEM Tremor shocks??
I'll save you the research. buy these parts for a reliable OEM equivalent that won't fail after 5k and don't think twice:
Bilstein 24-274951 x 2
Bilstein 24-274968 x 2
Optionally replace the steering dampener:
Bilstein 24-286558 x 1
Around 500-600 to do it all and very easy to DIY.
Around 500 to do it all and very easy to DIY.
Amazon has 4 5100’s for under $400. Took me 1.5 hours in my driveway taking my time, torqueing everything to spec and putting antiseize on the bolts.
Yah I’ve been looking at that route already, been researching Holstein 5100 series or ranch 9000. But since still under warranty I’ll get free ones til warranty is up
I’ll check that, I know when we hit - 50 here the vacuum didn’t hold in one and whirred then released. Issue with the auto hub in those temps, locked them and was fine til it warmed up, haven’t checked since I put back in auto
If you're ok with the truck sitting at the dealer multiple times for the same issue sure. For me my time was worth the 500 and an hour of my own labour.
I drive a lot of washboard dirt road everyday.
fyi I confirmed the hubs are covered as a powertain component, which is beyond the 3/36 warranty.
I had the same issue in the cold this year. I don't know the science, but I assume cold temps are simply decreasing the vacuum effectiveness.
From personal experience, I would avoid the Ranchos. I've had 7000s and 9000s and both sets had (multiple) premature failure. The 5000s seem to have a better reputation, but still Rancho. Once I put the Bilstein's in, it was night and day difference. Sold them with the old truck, will replace the Tremor shocks with Bilstein when the OEM shocks have any hint of failure. So far, still functioning.
You can reach out to us for our forum pricing and avoid paying sales tax in most states.
Happy to help if you decide to go the aftermarket route!
I recommend buying them from @Nick@ApolloOptics to support a forum vendor who has given lots of their time into helping others..
Thanks, man! Truly appreciate it!
You're sure it’s not your trailer hitch, right.
I’m sure you’ve removed it, but in case you didn’t think of it, mine clink and clacks when going over bumps sometimes.
How do the bilsteins ride I’ve heard they’re really firm, roads up here in Edmonton aren’t the smoothest
