- Jan 14, 2021
- 1,020
- 2,622
- USAF Retired
- 21 F250 7.3l Platinum Tremor, Lithium Gray
- 04 Ram 3500, 1150 rwhp, almost stock
Absolutely this adviceGive CJC Off-road a call. I'm sure they can and will offer you good advice.
Check Out Dynatrac ball joints and Moog ball joints for the Ford Super Duty trucks.Thank you. I looked him up and I maybe should have went with the 12.50 but still not sure this is the source of the problem. Thank you for your help.
I found a bad ball joint coming off the pitman arm. Not sure what the linkage is called on straight axle front end. Drag link? The ball joint has probably 1/16th inch of play. I will have this replaced and hoping this is the fix.
