shitIt’s shows to be in spec
Thank you. I looked him up and I maybe should have went with the 12.50 but still not sure this is the source of the problem. Thank you for your help.There have been a few reports of guys running 13.5’s having similar issues. Just wants to grab every groove in the road. There are also people running the same set up without any issues. F350soup on Instagram wrote a post about his experience with the 13.5 feel vs 12.5. Might be worth reaching out to see if it’s similar to what your experiencing. Hope you get it sorted out! ?
I discussed this with the alignment shop. They said I need aftermarket ball joints to adjust camber on straight axle. Is this accurate?Your front camber is out of spec., your too negative. This means the top of the front tires are tilted in on top, meaning your riding on the inside edge of your tire. OEM spec. is, -.6 to +.9, your at -.8. I would recommend trying +.2 or .3.
The caster seems too low as well. I would think 4.5 to 5.9 would be more reasonable with the 37's. Most alignments shops will add .5 degree to the right side to offset for road crown.
I recommend calling Carli to confirming some good alignment numbers and then find a reputable alignment shop that will work with you to dial it in where you like it.
I have dual steering stabilizers. After I get it back from the ship I will have them adjust caster. Thank you.It IS Castor!!!! Castor needs to be higher than the Ford spec...at least +4 or better +5.....that will plant your truck for sure....I would also heavily recommend dual steering stabilizers......thats my 2 cents....
Did I mention Caster???????
Yes there should be plenty of adjustments with the radius arms. Thanks for the input I’ll give that a try when I get it back.Can the shop add caster? it really did not change much on the alignment.
I had my guy add a ton of it to my Raptor when we put the lift kit on it. I know that s a different thing. but its often adjustable. I don't know if you can have too much caster. We added a ton of it on my Rubicon thats a solid axle and I have the Metal Clock mid arm kit on it. Lots of adjustments. It drives like a sports car with that kit.
Ok good to hear I’m not stuck with it this way. I’ll update you after i get it back from the ball joint fix. Thanks.I have a 5.5 Carli Pintop with 37" Toyo M/T's and my truck drives straight as an arrow and I never had an alignment done after install..
Something isn't right.....
Definitely call CJC they are very helpful
Hope it works out for you! I am sure with the proper settings or adjustments it will be awesome.Yes there should be plenty of adjustments with the radius arms. Thanks for the input I’ll give that a try when I get it back.
No kidding.Not a very helpful comment
most shops don't let you hang out while they're working for insurance/liability reasons. overall a dick comment that adds 0 value.so you got that lift installed and didnt watch/help the tech so you could learn your truck’s suspension makeup? Keep your truck on the asphalt bud.
Are you running new tires? Maybe it is a balance thing!?Hey all, I’m in need of help regarding alignment with Carli. Last week I had the fully optioned Carli pin top kit 3.5 installed. I am getting feedback from the steering with any imperfections in the road at highway speeds making it feel unstable. I’m on my second alignment, first with toe at zero and second slightly toed in. It’s improved but not perfect. Both hands required on the wheel on smaller farm to market highways.
I have dual steering stabilizers, progressive sway bar, radius arms, progressive leaf packs and track bar. Also running 37x13.50r17 nitto ridge grapplers.
I tried to buy all the best parts to have the best drivability but this pulling around constantly at highway speeds is frustrating. Any help would be hugely appreciated.
Right? Plus who has the time to stand around and watch coil springs be installed.most shops don't let you hang out while they're working for insurance/liability reasons. overall a dick comment that adds 0 value.
No kidding, it's literally why people pay pros to do this.Right? Plus who has the time to stand around and watch coil springs be installed.
