- Oct 26, 2020
- 2,090
- 4,386
- 2021 Tremor 6.7L Lariat Ultimate / Lariat Black
- 2023 Corvette C8 Stingray R
I think you will be fine with your +18 offset. I am running 37x12.5 Ridge Grapplers using 17x9 wheels with a +1 offset, and like @BroncoHooves, I have no rubbing on the factory radius arms. The 17mm difference translates to .67inch further in than mine. I was considering +6mm offset wheels and Carli told me there would not be a problem with them rubbing.Right now I’m spec’d for method 305 18x9 +18, 5.75. I wonder if that falls into the “high offset” realm? Going with recon grappler 37x12.5
If you want a solid answer, call Carli or one of their larger distributors and ask them before placing your order. Worse case, you will need to add their radius arms after the fact if the rubbing really bothers you. (It would drive me crazy, which is why I confirmed the fitment prior to buying)
