What rear blocks should I run with a Carli suspension, and at what height?
I'm upgrading my suspension to a full Carli kit with the progressive leafs, along with Firestone airbags and daystar cradles.
- According to this article by Carli, I should expect the truck to sit close to level with ~500 pounds in the bed.
- According to common wisdom of members here, I should expect that the truck will optically appear un-level when it is actually level.
- According to this post by Supercup, I should expect that the progressive spring pack will sag 0.5" – 0.75" after break-in.
In Carli's post, they claim their test mule had everything removed from the bed except for the factory spare. Although it appears that vehicle may have had a bed cover installed. It also seems likely it already had air bags installed. (I'm assuming this is
@cody_cjc's truck?) As such, I should expect that I may have ~280–400 lbs. more weight in my truck at all times than that mule had according to these calculations:
| Accessory | Weight |
| 5th Wheel Kit | 140 lbs. |
| Bumper Hitch | 50 lbs. |
| Bed Racks | 40 lbs. |
| Bed Mat | 50 lbs. |
| Sub Total | 280 lbs. |
| Air Bags | 20 lbs. |
| Air Compressor | 10 lbs. |
| Bed Cover | 90 lbs. |
| Sub Total | 120 lbs. |
| Total | 400 lbs. |
Accordingly, it seems like I should preemptively raise the rear of the truck upon installing the Carli leafs. Which blocks should I use for these specifically?
Are these what I'm looking for? What height should I go for considering all of the above? (I'm thinking 1" would be ideal, but I'm curious if anyone has first-hand experience dialing this in.)
cc
@BLACKCHERRY @Supercup
If you're loading the rear of your truck with 400lbs, a 1" block wouldn't be a bad idea. If you think you'll build on this over time and end up exceeding these estimates, you may want to look into the HD leaf springs. The HD springs handle the load more efficiently with heavier gauge steel - they'll have better longevity vs. a standard pack.
Get pmf 1.5 inch 2:5 taper, i’m barely looking level with them after some sagging of the rear leafs, with 1 inch it might be worse, in retrospect i should have went for 2 inch block without any worry.
@Supercup explained that at one point this spring Carli lowered their leafs height without telling anyone, so some people ( like me) ended up with rear leafs that were squatting. Not cool at all.
This is something we'd want to look into. The leaf springs were dropped 1" as they were exceeding our print by 1" - This was NOT a production change where we decided to lower the springs. We were getting complaints of leaf springs sitting high. We looked into it and Deaver was manufacturing springs 1" higher than the prints called for. We corrected this.
We have the full article that shows how the leaf springs should sit and measure. Unloaded, they should be 1/2" to 1" rear high. Once broken in, they'll MAYBE sag 1/4" but 3/4-1" is uncharactestic of any Deaver I've ever seen. I literally Huck my 9,500lb long travel Ram on Deavers and they haven't sagged 1/4" in the 5 years i owned the truck.
I would be happy to run over measurements to see if you're sitting low. We wouldn't put out a spring that "squats" the truck. Again, the article defines our intended stance clear as day - for what it's worth, this article was drafted after Deaver corrected the production.
Much like
@Alpoba I had about 1-inch of sag after installing a Carli setup w/ full rear leafs and airbags. I didn't like the look of the sag or the ride with the airbags inflated enough to bring it to level (when towing thew airbags are great!) After reading Alpobas post of what he did I contacted Carli about the sag, and they recommended the PMF blocks as a good solution. I went with the PMF 2-inch block and now have about 1-inch of rake which I like and helps the tonneau cover rails to drain properly (when level, I noticed much more water coming in from the rear of the rails, most all tonneau rails drain from the front) and it means that I don't have to put as much pressure in the airbags when towing. All in, it cost me $300, here are the parts that I used:
Hope this helps, YMMV
Hit me direct - like
@Alpoba - i would be happy to run over measurements with you to see where you're sitting.
That's a notable callout. It's a shame there's not further commentary on this on CJCs site. I believe
Carli's airbags are only compatible with their 4.5" lift? Otherwise I'd go for them.
And
CJC seems to recommend the Firestone's specifically for use with the Carli leafs, without the caveats that Carli is calling out.
I hope
@BLACKCHERRY is able to chime in here.
Sorry - This hit me on my trip to the mountains with my kids so i lost it in the notifications when i got back.
Airbags are a necessary evil - plain and simple. Our design is a rolling-sleeve bag that's lighter duty with a tapered lower piston and unbanded bag. This means our bags won't affect your unloaded ride but they'll require more inflation pressure and, as you go through the travel range, the air-spring rate won't increase nearly as fast as it would in a standard double bellow
We only offer them for the 4.5/5.5". Why? The 4.5/5.5 and 2.5/3.5 both use the same rear shocks. Technically, they both have the same rear suspension travel. The leaf springs on the taller kit obviously sit a couple inches taller. This being the case, it puts the bag in the center of travel. The lower lift height pushes the bottom airbag piston too deep into the bag - in most cases the bag rubber will rub the lower bracket. We can't shorten the bag as it needs to be able to reach the end of the travel stroke.
To work in both applications, we'd need the bag to meet the same compressed and extended bag dimensions AND, it would need to have enough lower piston showing at ride height to ensure a couple inches of up-travel before the bag contacted the mount. We couldn't accomplish this on the leveling.
We don't specifically intend to call out any manufacturer. The nature of the double-bellow bag kits it to add capacity - most have no concern for the ride quality. Many of these kit double and triple the capacity of our bags (2,000lbs of assistance vs. 5,000 and 7,500 in some cases).
In doubling and tripling the capacity, the baseline construction will obviously need to be more robust to handle the additional pressure resulting in additional air-spring rate. Same philosophy as a Carli Progressive Leaf Spring vs. a Stock Pack. One is designed to load, the other to ride well and still be capable of loading but to a much lesser extent.
i digress - these double-bellow kits aren't designed with extended travel suspensions in mind. They're short-travel like the factory suspension, in fact, much shorter when you use fixed mounting like they intend. Most of these systems run a bag that's only capable of 4-5" of travel while most factory trucks can cycle 2x that without performance suspension. But, again, they prioritize load control. Things like rear sway bars and airbags end up on trucks that prioritize control. Excessive suspension movement is literally the opposite of load control.
I could go on and on discussing this topic. The thesis is that people modding 3/4 and 1-ton trucks to ride better on and off-road are operating within the margins. We're the ones changing what these trucks do to make them look or act a certain way. You're not going to find many products that fit into the "performance" catagory unless the manufacturers intent aligns with the sliver of the market segment we're discussing here. Luckily, there are people making these products to ensure some capatibility for customers seeking it but none of these options are without their shortcomings.
