Carli complementary rear blocks
@Supercup based on other photos of your setup, I don't see the gap/ spacing that @Luth33 has on his. I remember reading there was a change in an earlier post. Either way, I don't think I'll need the spacer to take up the gap. Thanks to both of you for confirming.
I just realized I have the Sulastic shackles. I wonder if they are contributing to the lower height.
Slightly more expensive option than most air bags, but im curious if going with these with the carli 2.5/3.5 systems could eliminate some of the issues with travel? I talked to a local shop that said these were the best bags they have ever ran on any of their builds.
I remove the spacer and the cradle. Here are pictures with it installed and with it removed. You can see in the picture that the bump stop will come in contact with the axle before the airbags hit. I know it may seem like a lot to some but I like the way the truck rides without the airbags interfering with the suspension. But I still like to be able to use my vehicle as a tow vehicle and it’s no different than hooking up my weight distribution hitch and changing the tire pressure every single time I tow, this is just one extra step I do. you can see my trucks sits perfectly level loaded down with my dirt bike, firewood, extra propane, tools, a 37 inch spare tucked into a Carli hitch and a 60 gallon fuel tank. I have the full Progressive rear leaf springs. And only 25 psi in my airbags.
Thanks, what tires and wheel offset do you have?
I have method 701’s with +18 offset and nitto ridge grapplers 37 12.50 18.
As I was responding to some of these posts I saw that CJC now has a new airbag system that’s looks pretty cool, although it pretty expensive. It basically does the same thing I do by pulling out the spacer and cradle. I had not seen it before. They didn’t have them when they installed my suspension in August. But I think I would have done that system.
I was just taking to them last week and they said they were testing a new one so I held off, headed there now to check it out. heard lots of bad stuff about the ridge grappler on here do you like them? Was just looking at the Toyo RT trail and according to Toyo it beats their regular R/T at everything.
Just looked at that new airbag kit. I don't see how it does anything more than what you are currently doing, can't see how it would allow for more travel than the Firestone kit, and almost 1100 more:oops:
I’ve heard a lot of bad things about the ridge grappler‘s too. I think I’m gonna try the Toyo tires the next set I get. I think the side walls are just really stiff on them and is not a great ride. Going from the stock set up to the Carli suspension and the lower tire pressure was a pretty dramatic difference in my opinion. So going with an even softer tire would just make it that much of a better ride.
I would agree with you that You’re not gaining anything over the firestone airbag kit if you take the time to install the spacer and cradle and then remove it when you’re done. With the new air bag kit they have that is all they’re doing. But that makes a world a difference as far as the suspension travel goes. The airbag should not interfere at all with that spacer and cradle removed. The kit that they have just makes it really convenient. It looks like it’s just a pin that slides up and down and pops into place. On the way I have it set up I have to bolt it in and out. It’s only one bolt and doesn’t take me more than five minutes to do on each side it’s just not quite as convenient.
@Tx-Tremor6.7 if the factory bump stop is still on there how would they get damaged at 0psi?
@Luth33 do you leave yours at 5psi when you remove the cradle and spacer or go to 0?
I totally agree, I don’t think the airbags would be damaged because it hits the bump stop first slowing down the suspension before crushing the bag. I run zero psi in mine so that I don’t get any interference at all. We are asking a lot of our trucks, we’re trying to get it to ride like a pre-runner yet expecting it to haul heavy loads. This is the best way to get both, but it requires a little more work on our part to make it happen.
yeah if it was a few hundred more I'd try it but 1100 I an unbolt it, it is cool though
Pros
  • The on-road tracking and handling in dry conditions is superb. Almost feel like sport/summer road tires.
  • They tow extremely well. Night and day compared to the Duratrash. Very solid and stable feeling.
  • Very easy to find in stock everywhere (I've damaged two off-roading and found same day replacements in small towns.)
  • They work really well off-road in dry conditions, whether in sand or on slick rock.
  • They look really good on this truck.
  • They don't collect gravel at all. By contrast the Duratrash throw rocks all over the road everytime I leave my driveway.
Cons
  • They are hard as rocks. At any tire pressure. I'm guessing this is where the handling/towing ability comes from. You can really feel the road underneath you with these things. Just like summer tires on a sports car.
  • At anything but near max pressure they develop a bit of a flat spot when the truck is parked. I'm skeptical of the longevity of these relative to the stock tires. I'm guessing this is the one area the Duratrash would have NRGs beat.
FYI
  • They don't clear mud well — but they're not meant to be a mud tire.
  • They're just OK in the wet conditions. As good or better than the Duratrash. But not exceptional.
  • I haven't run them in real snow or ice so can't comment on that.
As compared to Toyo R/Ts, all I can say is that the compound appears much harder. You can deform Toyo R/T's by pressing on them with finger pressure. The rubber on the Nitto's just doesn't budge. I don't know what that would translate to on the road with R/T's but my fear would be they'd feel squishy like the Duratrash or other similar A/T tires.
I originally meant to go with the R/T's and ended up with NRGs by fate. Now thinking about what to put on another vehicle and feeling really torn. I'd like a slightly more comfortable tire but would have a hard time giving up the stable feel of the NRGs for another squishy tire like the Duratracs. All-in-all I've ended up happier than expected with the NRGs.
Pros
Cons
FYI
good review, I am surprised how many rocks the duratracs throw and mine are on a 22 they aren't great in snow. I'm thinking about Yokohama in the 315 70 MT or 37x12.5s in Nitto Mts, Toyo RT trail or falken RT, falken has deeper tread depth than any of the other RTs was going to try KM3 but they seem to be at least 610$
The Airlift airbags replace the factory bump stops, so they are gone. The 5000 lb Ultimate airbags have an internal jounce bumper, but it is not as big as the factory bump stops.
If you use the Airlift wireless controller, the lowest setting is 5 psi. Every time you start the truck, they automatically fill to the current setting, so 0 psi is not possible. Airlift recommends using 5 psi even with their Ultimate airbags.
Has anyone gone with backcountry with factory leaf springs and replaced the tremor block (3.25") with a 4.5" block to maintain most of the factory rake?
Adding a bigger block or stacking blocks is not recommended due to the potential for axle wrap when driving off road. Most of us have removed the factory blocks and used a full progressive Deaver leaf pack or their Add-a-Pack under the factory leaf springs.
Yeah that makes sense. I'm trying to maintain full towing capacity as I get all the way up to max for this truck. I also like the factory rake. I'm just not sure that the HD spring pack is necessary because I don't have constant 1000+ lbs in my truck.
Looking through your build, how do you feel your truck performs loaded and unloaded with the add-a-pack option and a 1" pmf block? I haul a 5th wheel with close to 3k pin weight and I'm really not thinking the full progressive pack will work. Did you end up adding the radius arms or are you using the factory ones?
I tow a 42’ Solitude 5th wheel with almost 3200 in pin weight, so I know exactly what you’re trying to achieve. I did not want to lose towing or weight carrying capacity, so I went with the AAPs. I also added the F350 Sulastic Shackles to soften the rear leaf springs, and I have the factory radius arms on the front. (Carli said the only reason to buy their radius arms was if you were planning to use a much higher offset wheel)
The truck rides fantastic when I am towing, and if I lower the air in my 37x17s to 40F/38R, it rides pretty good unloaded. It will never ride like a plush F150, but I think the combination I have works very well for a SD that can tow up to its limits.
Right now I’m spec’d for method 305 18x9 +18, 5.75. I wonder if that falls into the “high offset” realm? Going with recon grappler 37x12.5
I have 17x8 +0 offset and no rub on factory radius arms (22 model year)
