On Mon, Jun 6, 2022 at 9:53 AM Info Carli Suspension <[email protected]> wrote:
Does this sound right for a 250 with the HCTTP? I want to keep the towing and hauling capacity and have the truck level while unloaded. I'll add bags if needed.
I have been in email communication with CJC. They said to buy the rear blocks from a 2019 and then the Commuter package with high mount stabilizer and sway bar drops.Hello Txxx,
The high-cap tow package complicated things as you have F350 Rear springs and Axle.
These springs do NOT pair well to our add-a-pack and the factory springs do not pair well to the Backcountry shocks. The Backcountry shocks sound to be the perfect match to your application.
In short, Only the sway bar and rear leaf spring option are technically “required” to complete the kit.
If you’re wanting something that’ll be a “good” scenario, you can option the 3.5” Commuter with the sway bar drops and stock leaf springs (no rear option). The Commuter, being an entry level package, will ride better with the stock springs. This scenario will leave the truck perfectly level but some elect to add a 1” taller block that factory, the retailer of your choosing can assist you with this. When hooked up to a trailer, you’ll have your factory payload capacity BUT you’ll sag below level as your truck is now level when unloaded. It’s an imperfect scenario that leads many customers to add airbags to level the truck when loaded.
If you run the factory springs AND airbags, you ride on the massive, superfluous spring rate when unloaded, then, when hauling, you engage the airbags to unload the factory springs rending their capacity worthless. This is a ton of unnecessary, redundant spring rate. If you plan to run airbags, run a lighter spring on which you can ride when not under load and benefit from their compliance, THEN add the airbags to adjust the capacity in the rear for your varying loads.
All this leads me to recommending the Backcountry, Torsion Sway Bar, and full progressive leaf springs as the “best” option. Add your selected airbags and you’ve maintained your capacity and added rear load-height adjustability while you enjoy the softer spring rate of our progressive springs when unloaded.
As we do not sell direct, I’ve copied CJC Offroad to run over the additional options and pricing.
Regards,
Customer Service & Tech Support
Carli Suspension
596 Crane St. | Lake Elsinore, CA 92530
(888) 992-2754
[email protected]
www.CarliSuspension.com
