Camping and drained battery?
Mattlikesbikes
Austin TX
2022 6.7 Lariat Tremor
Have camped a few times in the back of the truck. All has otherwise gone well. This morning had no problem starting the truck to pull it forward a couple of feet to give myself a little bit more room on my pull out kitchen. No issue. But after that I left the truck unlocked with my keys in it. Maybe a door was partially open. Who knows. I then proceeded to do stuff around camp for about 3 hours. Came back. Dead as a door nail. Barely tried to start so I called the ranger. We sat with it on his gas truck with jumpers where it took almost 20 minutes before we got up enough charge that it would start. 45 min drive home and all has been well ever since.
I know sometime last night I got an update. Bunch of stuff is different on the screen. Settings changed. But never seen it this dead. 3 and 1/2-year-old 2022 with dual batteries. Just ordered the gb150 jumper because my gb40 didn't even touch it today. Thoughts? What accessory could have drained it in 3 hours?
ouph, I'd be looking at a GBX155
Just went thru something similar on a 2023 Denali 1500. Ended up having to replace the battery with a new 850CCA unit.
Most everything in the truck is supposed to shut off even if the door is open. It would be strange that both batteries would be dead enough to cause this but not inconceivable. Do you have anything hooked up the upfitters? In particular, #5&6? If 5 and 6 are set to stay on at all times via the fuse position under the hood, an accessory tied into that circuit could drain the battery.
If you don't have anything hooked up, then I have to question the "key" situation. Do you actually have a key, and was it left in the ignition? (Assuming you don't have pushbutton start) Since you have glow plugs, perhaps it was set to where it was trying to start but didn't?
The fact that it took 20 minutes to gain enough charge to start, and the fact that it started earlier, I'm inclined to think something drew the battery down fast. Even though you say it is fine now, I would still be looking for some anomaly.
If you still have the original batteries, you may want to have them load tested. If they are borderline good, and since it is a diesel, they could have been drawn down with the door open and something operating in the background, far enough that when the glow plugs came on, it pulled them the rest of the way down.
So, batteries first, then look for a phantom draw. (Not parasitic, something acts like it "stuck" on.) Ironically, if the batteries are low to the point the computer is confused, they may cause things to stay on and not time out like they should.
A note on the GB150, I opted to go with the GBX 155, it has 4250 Amps, enough to somewhat overcome a dead battery and better for diesel. More money, but for me, peace of mind.
Hope you find the issue.
I was working on my truck in the shop with 3 year old batteries. Opening and closing the doors 20 times over 2 hours killed the batteries, was surprised.
Also run 2 jump boxes one for each battery, if it's slightly cold out you still have to get past the draw of the glow plugs before it starts to turn over. Both jump boxes went from 100% charge to 0% so you get one shot.
My truck is same age as yours is - had one battery die just before warranty was up, dealer replaced under warranty. No issues since, but 2nd one needs to be changed soon. Truck needs both batteries to start and if one is done - it won't start. I also carry a GBX 155 and when I was dead it did what was needed to start the truck! I really like the GBX 155 (also have an 80 which I now just leave in the SXS) as I have also used it for others and it has never failed me, even used it for a guy who was dead in the street and it would jump, but as soon as you took the jumpers/battery off it died - so we hooked the the GBX 155 up and he drove six miles to the auto parts store using the 155 as his battery source to keep it running.
Given your age, I would just swap out both batteries.
