Built Rite Rack & Fire Extinguisher
I'll post two cents worth here; The Element MUST be used properly to be effective. It has some drawbacks in an emergency situation. Here's a video of one persons review. There are many reviews, many positive and some negative. Check them out for yourself, and be prepared for the situation you might be in.
As someone who has been in multiple crashes including 2 rollover crashes, one of those involved my hand being crushed between the street and a Mercedes. These are valid points and worth thinking about. I am curious about devinhallen saying “they are garbage and should be thrown in the trash”…fyi I was not the driver in any of those crashes lol
They absolutly fail in fire scenarios. We tried in 6 different scenarios and 5 of the 6 times they were completely garbage. The one time it did work, it took long enough that the fire didnt really expand and may have been dying anyways.
Many racing organizations have since banned them as theyre ineffective.
Interesting
In the video above, the guy has the extinguisher too close to the flame. You can't put out a fuel or grease fire like that by just smothering parts of it at a time as if the flame isn't going to spread right back. That applies to any fire extinguisher. You've got to cover the entire thing.
Arguably, a traditional extinguisher might work better on that type fire if it has a broader spread, making it easier to cover a wider area.
We keep two elements in the truck, driver and passenger side, mounted to the side of the center console. Also a standard extinguisher in the bed.
A fire is to be fought at the base. Period.... start 4-6 feet away and move CLOSER when the flames are not your way. HE fighting that fire the most effective way possible. The element has less than half the reach of a traditional extinguisher, you have to get closer.
I see you're invested in Element... I highly advise you to junk them.
Having gone through a couple different (specialized) firefighting schools in the military and operating most types of fire extinguishers, as well as putting out numerous fires, I'll say no extinguisher is good for all types of fires. Each one has very specific conditions that make them effective. (Or not) Open fires with wind is darn near impossible to put out with conventional extinguishers. In a situation where the environment is closed, Element type extinguishers would be effective. (Under hood, hood closed, cab, in house pan fire, (type W) etc.) This is also true for C02, Halon, and any other gas extinguisher designed to remove oxygen.
If you watch the negative demo videos closely, the Element is being pointed very close to the base of the flame or the fire is in an open area with wind. The Element itself is putting out a flame! With wind, this can exacerbate the fire, reigniting it. It's a very different type of extinguisher and must be used as designed to work and in the ideal conditions. Therin lies my concern with the use; most people won't take time to figure it out until it's panic time.
Where they demonstrate as effective, (usually oil) the fire is in a contained pan where the gas can settle over it. (Just like C02 or Halon) They never put the Element itself directly on the fire or in the vapor caused by the fire. And again, with little or no wind.
All that said, I don't use the Element. I carry two 2.5 lb. dry chemical extinguishers at all times, separate from each other in case I can't access one. I've had the best result with dry chemical in the few fires I put out with them. (I had one fail on me once, another reason to carry a backup) (Halon is also effective in that it somewhat adheres to the source, but very expensive.)
Dry chemical covers a fire, smothering it, and is the best for open type B fires, can be used on C fires (electrical), and small A fires (combustible). It makes a big mess and can cause damage to the fire source. But it's better than watching it burn to the ground.
Open Type A fires, as usually demonstrated as evidence that the Element is a "bad" extinguisher, are best put out with good old water. Administered properly, water can even be used on oil/gas fires, if you know what you are doing and have the right distribution. (fog) (Not for the inexperienced)
Education is key when fighting fires.
By the way, if I were you, I'd pick some different folks to ride with to avoid those accidents... :ROFLMAO: :ROFLMAO:
Any concern about using an oxygen displacement type extinguisher in an enclosed environment like a vehicle?
This is absolutely true but if you have to choose one, I vote for the biggest ABC extinguisher you can bear. I carry a 7.5lb one in the bed. It's better to have too much volume than not enough, and it's better to have a versatile extinguisher than a specialized one since you really can't control what type of fire you're going to have to deal with in an emergency. I see a lot of people carrying little kitchen-sized extinguishers and sure hope they use it perfectly or they may as well throw it at the fire and run. One-and-done is a pretty dangerous plan.
I agree, carry the biggest one you can find space for. 5lb is better than 2.5, 7,5 gets a little bulky for me. Carry two if you can find space. If my vehicle is on fire where 2, 2.5lb extinguishers can't suffice, I'm walking away and filing an insurance claim, or hoping someone else comes to my rescue. If you've never been in a situation where your car/truck is on fire, you really don't have much time to react. Every fire is different, and you simply can't plan on how you're going to put it out.
I had a 67 Cougar that caught on fire under the dash, The ammeter shorted out to chassis. (long side story there, but very bad design in those days) A 2.5lb was sufficient to extinguish the fire but the damage was huge. New dash, windshield, wiring, smoke soot everywhere, if it hadn't been my only mode of transportation back then, I would have walked away. Also sustained 2nd degree burns on my hands.
The real odd story was that I didn't carry an extinguisher back then hence the fire was escalating as I was scrambling to find anything to put it out. This was in Grants Pass Oregon in the winter, snow on the ground, and I was literally hand-dumping snow and antifreeze I kept in the trunk, into the vents to put it out. No luck at all with that method. (Panic mode) :(
Had it not been for a trucker that stopped and handed me his extinguisher, it would have been history. It only took 2 or 3 seconds, and it was out. In the aftermath, the police and a tow truck showed up and towed me into town where I stayed for the night. I rewired it the next morning with burnt fingers, enough to get it to run and get to my destination. You talk about pain...
Honestly, to this day my biggest regret was that I never caught up with that trucker to say thanks for the extinguisher.
Nope. If my truck is on fire inside, I'm getting out. Then I'll asses on how to fight the fire.
After thinking about this thread I decided that having the second fire extinguisher under the rear seat probably wasn't the best option for accessibility, so I fabricated a mount out of scrap material to put it under the driver's seat.
It still allows for full seat adjustment without interference and is easy to find the release button. It tucks up under far enough that my feet don't hit it, which was my main objective.
Great idea! Stand by for duplication... ;)
Great idea.
I am of the believe that if its on fire, and no ones in there, let it burn. I dont want a half burned vehicle being repaired.
a 5lb is a size that is manageable and can be stored in most places. A quality current on inspection METAL 5lb extinguisher is what will work for 99% of everyone.
However, if theres a source of fuel or oil, it doesn't matter how big your extinguisher is, it wont put it out.
Same here... used the mount/clamp provided with the extinguisher I purchased from Costco. I had some extra Builtright fasteners I used to mount it to the panel. 1/4 - 20 I believe...
FYI - the fire extinguisher I used (see above) is currently on sale at Costco - at my local one at least. I have one of these in my RV as well...
3-A, 40-B, C
Ever been in a vehicle when the halon goes off on accident…fml lol
