Built a searchable AI "shop manual" for my 2021 F-250 7.3L
chrisnack
Madison, WI
2021 F250 KR 7.3
Hey all, wanted to share something I put together over the weekend in case it helps anyone else.
I had the factory service manual on the old Ford TSO install (the CD that only runs in an ancient IE viewer), plus a pile of PDFs: owner's manual, towing guide, brochure, upfitter switch write-up, and the install sheets for my Pacbrake air bags and Logiq HD2 controller. The problem was that none of it was searchable in one place, and half of it was stuck in that viewer.
What I ended up doing with Claude (Anthropic's AI):
  • Got the TSO content out of the viewer. Turns out the archives are a fairly simple container with light compression, so it was able to decode them into regular HTML pages, wiring diagrams and illustrations. Every page came out clean. The 2021 install actually holds Ford's whole 2021 lineup, not just Super Duty.
  • Turned it all into plain text files with an index, one file per procedure, each tagged as 7.3L, 6.7L, 6.2L or general so it doesn't hand me diesel procedures.
  • Pulled the wiring connector data into tables, so "where is connector C920 and what's the pinout" is a quick lookup.
  • Added my own stuff: window sticker and door label data, my service log and mods, and the air bag / compressor install manuals.
  • Made it cite everything. Every answer has to name the Ford section and page, and if it's not in the data it says so instead of guessing.
Now I can ask things like "front caliper bolt torque" (55 lb-ft per the F-250/F-350 page) or "which fuse feeds the upfitter switches" and get the answer with the page it came from. It can even send the factory illustration to my phone.
A few things it caught that surprised me:
  • Ford's own docs disagree in spots. The service manual and owner's manual list different oil spec codes, and the 120V outlet is rated 400W in one and 300W while driving in the other. It flags those instead of picking one.
  • A lot of the "severe duty" maintenance intervals floating around online are actually the diesel schedule or the extreme band, not the 7.3L gas numbers in the owner's manual. Worth checking your book.
Not plug and play, and I'm still figuring out the best way to get it all on my phone when my PC is off. But if you've got the TSO disc or the PDFs sitting around, it's pretty straight forward to make them a lot more useful.
Happy to answer questions on the approach!
Just to be clear, i use Claude code about 10-12/hours a day on average, so i'm not a typical user, but it's actually quite simple to do/replicate.
Brilliant idea! Thank you for sharing. I hope it helps others. AI for the win!
I've got my full maintenance records in there now too and it tells me what is coming up next etc... i'm messing around with putting into a GIT repo so i can access fully from my phone without computer access. Messing around with the photos and schematics since it's alot of images, seeing if there is really value before i stick all those into it. But even just the full text is pretty darn helpful.
I was troubleshooting something this morning on my radar detector not having power and that's through the pass-thru wires, so that is what prompted all of this because i was tired of walking downstairs to my computer to look up the wiring in the CD on my computer. :)
