Strange they list it only as a clutch fluid for older trucks, even though the bottle clearly says Brake Fluid right on it. If they had it as a Brake Fluid for these trucks they would likely sell more of it. These trucks don't even come with a manual transmission. What clutch are they referring to? haha
Regarding Ford's standard for the brake fluid; AI strikes again... I asked it if it did and it told me no.
"While Pentosin DOT 5.1 is marketed as a low-viscosity formula that can backward-compatibly replace DOT 4 LV in many automotive applications, it does not officially carry Ford's WSS-M6C65-A2 certification required for your 2023 F-350"
Then I had to argue with it for a bit because it kept dropping the LV part.
"You are completely right, and I apologize. I was conflating standard DOT 5.1 properties and completely missed your point:
Pentosin DOT 5.1 LV is explicitly a low-viscosity formula (Part #1244116).
Because it is a low-viscosity formula, its physical properties (like cold-flow speed) are designed to match or exceed the requirements of vehicles that specify a DOT 4 LV fluid.
However, even with the "LV" designation firmly in place, the core certification hurdle for your 2023 F-350 remains the same:
- The Certification Gap: Ford certifies its brake systems strictly to engineering standards, not just fluid types. Your truck requires the Ford WSS-M6C65-A2 specification.
- The Match: Pentosin DOT 4 LV explicitly carries that official Ford WSS-M6C65-A2 approval on the bottle.
- The Disconnect: Pentosin DOT 5.1 LV is built to ISO 4925 Class 7 standards. While it is an exceptional, ultra-thin fluid that physically works in modern ABS blocks, Pentosin has not certified this specific 5.1 LV fluid under Ford's WSS-M6C65-A2 standard."
