Time for me to get ahead of it and replace my original batteries with AGM’s.
After reading about the Odyssey’s here, I figured I’d go that route.
Just as a total coincidence, a few weeks ago I stopped by my Dept’s corp yard to drop off a couple dozen donuts for the guys and catch up with some of them (a habit I was doing while still full time- which resulted in me never having to wait for issues that came up with my patrol units or later on with my take-home vehicles). I mentioned it was time to think about upgrading the batteries in my Tremor to Odyssey’s. They told me to take a look around back at the hazmat storage area. I walked over and saw two pallets full of them stacked up and waiting to be properly disposed of. I figured they were replaced for normal life expectancy reasons but noticed quite a few looked fairly new!
The guys said that the current batch of patrol units are arriving with the Odyssey’s and they have had quite a few not holding up to the daily use of the patrol units and are requiring their replacements within a fairly short time. They are being replaced with identical Odyssey’s.
Granted, my Tremor does not see the severe duty that those batteries have to go thru on a daily and mostly a 24/7 schedule!
So now it has me thinking I should look into alternative batteries. I’ll do a search here and see what direction the latest suggestions are going.![]()
Give these a try.....
I've had good luck with the X2 power batteries, I even put one in my tractor.Give these a try.....
Doing very well for me.
Same.I did not bother with a warranty replacement when my batteries went bad on my 2022. Replaced them with AGM batteries and called it good. I was quite happy to see that the 2024 came with AGM batteries right of the bat.
I just had my passenger side replaced for leaking and the driver's side replaced 2x for leaking under warranty. I plan to swap them for the X2's at the first sign of another leak on either of them. I have the same billet battery tie downs as Lunch Box waiting to be installed but I won't use them with the stock garbage.
I have a22 platinum with too much digital crap. I had steering wheel turned at 45 degrees and drove perfectly straight. At said power steering assist (oxymoron) needs servicingI recently had both batteries replaced following 2 issues...1 was on start up, the truck would crank like two cranks then it would stop, then would start on the next try and 2 I had a power steering fault...both batteries were replaced and I have not had either issue since then
