Oohhhh... I like thatNo more fumbling for the heater cord when it’s-20View attachment 17099View attachment 17100
Very thin. Less than ¼".@RedZilla Can you tell me how thick this Ford plastic trim is? I'm placing an order for some black chrome bolts for the Noco inlet and want to make sure I get the correct length without having to trim the bolts down. Last measurement I need. Thank you!
I believe I used 1/2" 10-32 SS screws on mine. I used SS nylon locking nuts on the back side to secure. I used a 2" knockout tool for the whole but a whole saw will work also. Knockout tool is much cleaner and safer if you have one.@RedZilla Can you tell me how thick this Ford plastic trim is? I'm placing an order for some black chrome bolts for the Noco inlet and want to make sure I get the correct length without having to trim the bolts down. Last measurement I need. Thank you!
If you can measure the thickness of the plastic piece that would be awesome.I believe I used 1/2" 10-32 SS screws on mine. I used SS nylon locking nuts on the back side to secure. I used a 2" knockout tool for the whole but a whole saw will work also. Knockout tool is much cleaner and safer if you have one.
I love this idea. I bought 1 for engine block heater. Now I just ordered a second one.I bought and installed 2 of them because you showed it to us. Thank you! One for the block heater and one from the future dual battery maintainer.
I have the diesel 6.7 and I only saw 1 battery on my rig. I Now want to run a battery tender I guess. I’d love to have something that I just plug an extension cord n and it would jump my truck OR just wait it out and recharge my battery.
I always was wondering if my battery dies and the truck is locked how do I get my n to open hood to jump start her.
Any help on what I should get to install to my battery would be greatly appreciated.
Thanks brother.![]()
I’m sorry to ask but HUHIf you have a 6.7, you have two batteries.
Mounting and Anderson connector that is directly attached to your battery is the way this is normally done. You could also do a remote battery post kit.
Ironman, I haven't installed any type of battery tender yet so I don't know what one to tell you to get. I do know that I got the idea from Richtor on a previous post but I'm not good at looking up old stuff and linking it. I believe it was some sort of a marine application for a trolling motor and the boat motor so therefore you could hook two batteries up to it at the same time. If I run across it I will let you know what I find. Sorry. I'm sure someone else will chime in with the correct item.I love this idea. I bought 1 for engine block heater. Now I just ordered a second one.
I’m going to have it done for me and I’d like to just say here this is what I need to get done.
So a bit more in depth would help me out. What kind of device should I get.
Sincerely Thank You Brother![]()
Looks like it's available on Amazon.
Ed
You got a pair buddy!I’m sorry to ask but HUH
That looks good. Now I gotta get another one and a battery tender to plug into itI bought and installed 2 of them because you showed it to us. Thank you! One for the block heater and one from the future dual battery maintainer.
2 inch is what you need. It was the one size I didn't have so I had to order it when I did mine.So has everybody used a 2 inch hole saw bit for this or could you go slightly smaller? Just trying to cut the smallest opening possible.
