BD lights help with product
Hunterman
Tremor Addict
Sacramento, CA
Chevy 2500JD
I have seen a couple trucks with lights in the front license plate / winch area. What lights and bracket is that? I already have the squadron fog lights and want something that will direct more light straight out in front of the truck. What would you all recommend for straight or distance lighting? I really don’t want to go pillar lights but will if I have too
It depends on your needs. I ordered the fog pocket replacement ones and the a pillar ones, took the truck out on my usual sxs route and realized the fancy headlights are dogshit and the fog pocket will be aimed directly at any elevation increase you’re facing so adding the a pillar lights for some further throw was my reasoning.
Went through this whole ordeal when building my SXS. Baja’s lighting zone guide is an excellent reference, but I would recommend low floods for ditch / low speed stuff and powerful spots for spirited driving or the need for further visibility.
I have the Rigid 10" E-Series Pro, driving pattern. At 18,810 lumens, you won't find a brighter light for the price of that size. My shop got it last year for $549.
If you don't want pods, this is your best bet:
If you choose the spot pattern you will lose 3,000 lumens but a more focused beam:
Gracias….. I think that is what I was looking for. Thought it was BD but I guess it was Ridgid
De nada mi amigo!
I can't remember if my shop used a bracket, I don't believe so though. Another cool thing about this particular size is you don't have to relocate the ACC module (if you have one). If you don't, you can get a larger sized light and maximize output.
Lights?!?
I like lights. Lights are good
And what do you know about lights!?
I used existing holes in the upper part of the bumper and attached using fender washers. I wired them up with a harness that hooks them into the added BD light kit for the 22, using an upfitter to turn them on. I believe there are similar products for the 23 and up.
I also made a "magnetic" bracket for the lower lights in this configuration; Even though the magnets hold them in place, I attached them to the frame and backed them up with a couple tie wraps. They are secure and don't fall off in rough terrain. (And yes, they still have full clearance on the approach to a hill.)
All that info....and the truck info we really need isn't there. Why not add the Ford truck info to your profile ?? :unsure: :unsure:
There's a few options out there:
(1st pic without brush guard) ZRoadZ discontinued a 12" bracket/light kit. The light bar wasn't crazy bright, but super easy install that doesn't require removal of the bumper or anything. I don't have ACC, so not 100% it fits if you have that. ***I have my ZRoadZ bracket in mint shape sitting in my shop if you'd like to buy it for cheap. It's good for most 10-12" light bars.
(2nd pic with brush guard) KDFabworks makes a 10" or 20" bracket that fits Baja Design, Rigid, and Diode Dynamics 10" (or 20") light bars that is super nice. Also direct bolt-on without removal of anything. I am now running this bracket with the Onx6 10" from BD in spot and it's crazy bright. Compliments the 4 BD Squadron's nicely!
Or a 20" bracket too:
(3rd and 4th pic) This is a very low profile ZRoadZ bracket that holds a 30" straight or curved light bar. Obviously doesn't fit in the lower, but it's a simple 2 bolt installation that doesn't require any removal of anything and doesn't stick out very far. Obviously a quality 30" light bar will through some serious light!
(5th pic) Lastly, there are a few options if you wanted to mount a light bar/BD LP4/6/9 across the front with a something like Factory Aftermarket or similar bracket that mounts to the front bumper bolts. That lets you fit pretty much anything you can image.
