Baja Designs Dual Fog light 2020-2022
@GeoffH that's a great video! Assuming you have the Baja Designs amber SAE lights and then the clear/white Baja Designs Squadron Pros? SAE lights are rated for on road use (ie, don't blind all oncoming traffic) so your video certainly shows them providing great auxiliary lighting to your headlights. And then of course, the crazy blast of white light which completely out shines your headlights from the Squadron Pros is awesome. The other great feature about Baja Designs is they offer replacement lenses so you could easily swap your Squadron Pro clear lens for an amber lens should you ever want a ton of amber light. Pretty cool to be able to swap lenses without having to buy a completely separate set of lights or void your warranty on the lights like a lot of other lighting companies.
You assume correctly and no oncoming traffic were harmed by the squadron pros
Has anyone noticed an increase in noise after installing these. There is a wistle/drone with my truck now above 80 that appeared the day I installed these. I know its wind noise and its annoying as hell. Loud too. Really grates on you on a long interstate trip.
also did others put back the two stamped steel reinforcing pieces the oem fog lights were attached to? The instructions didnt mention it but I just thought it added back some structural integrity. Could be those whistling as the air passes around the lights. Just figured I would ask before I started investigatin.
please troubleshoot this before I get mine installed! I have wind noise from my mirror lenses on my 15 and it drive me nuts! :oops:
Honestly I think the stock LED's look better
I agree but limited options for better lights. I have rigid sae on my 15 truck and never get flashed and provide tons of light. I am guessing the baja are that much better!
Did you set the pods as far forward as possible or set them further back which would leave a bit more of an air gap.
Also saw this thread earlier that might be helpful to close up the backside and help minimize potential air pass through.
Post #2715 in thread 'What did you do to your Tremor today?'
https://www.fordtremor.com/threads/what-did-you-do-to-your-tremor-today.69/post-207119
They are as far forward as possible because thats the only position that will let them rotate centerline enough to be straight ahead. when back they point like a rabbits eyes. Thanks for the link ill give it a look!
Haven't noticed any noise with mine
Did you put all of the metal pieces back in after install? The instructions don’t show to do that but I did.
I taped over them this morning so seal openings and it’s quiet now. Not a permanent fix though
Yes, I reinstalled the heavy metal bracket on back. When I first removed it during the install, the bumper flexed a touch so I decided then that everything not light related was going to be put back as before.
Yes everything is back except the fog light and bezel. Pretty sure lights are pushed far forward as possible. Also put the tape they supplied completely around the plate
Thanks for the responses everyone. Ive ordered a couple of the pieces referenced in the thread above to try and block off the airflow from the back side. Ill update once installed. Covering them with tape did stop it so it is the lights. Happens above 85 and gets progressively louder as speed goes up.
If your factory wheel isn't heated (or you don't mind losing the feature) and you do NOT have Adaptive Steering, I have a similar Raptor style steering wheel available in leather and carbon fiber that's way cheaper than the OEM stuff. Just a head's up.
What set up do you have for a 2021 F350 lariat? I do have adaptive steering on mine.. Otherwise, I would have the raptor wheel. I just don't like the lariat wheel. I had a platinum before and that wheel was so much better.
We can accommodate custom orders and have for other customers.
One thing I'm curious though is that you mentioned in your other post that you wanted a cut-off line. Are you intending run these on the street? If so, I'd go for the SAE lights as one pair and the PRO Driving/Combo as the other pair.
That said, if you want to go custom, we can make it happen.
Cheers,
Nick
So I drive mostly in the city and occasional mountains and snow. My main goal would to be able to see the road ahead and sides better. I am trying to figure the best set up. So the amber is street legal and the white isn't? I am adding the xl linkable kit as well for offroad and cool looks. What is the recommend fog light set up and which are connected to fog light, upfitters, etc.? Thank you.
How is things going now, noise??
The kit includes two pair of pods. One pair is street legal (SAE) and they're available in white or amber, both options are street legal. The second pair of pods is going to be for off-road use, Squadron Sport or Squadron Pro. The only difference is how bright you want the off-road lights.
We can also customize the kit put in any Squadron light you like. So I you wanted two pair of SAE lights (one white and one amber), you could do that.
One set of lights will work from the fog switch and the upfitter will turn on all 4 pairs of lights. You can also wire them up to two different upfitter switches, if desired.
We have all of the Squadron lights in stock, along with the the Baja Designs fog kits and the XL Linkable kits, no lead times or anything.
Feel free to send me a PM if I can help answer any more questions for you.
I run these lights, got them from Nick. They are just awesome. One of the biggest advantages in the BD lights is the color of the light which is much easier on your "night vision" in the human eye!
Does Baja Design have a backlight/running light option on their pods? I couldn’t find it.
I was comparing manufacturers recently trying to figure out which Pods are best for me (rigid/diode/baja design) and learned that Diode has a backlighting / running lights feature in their pods. That was a WOW to me and an instant decision to install them over anything else on the market.
“Backlight Functionality. The Stage Series 2" LED Pod includes a distinctive backlight feature, in your choice of white, amber, red, and blue. The SSC2's backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.”
So not only do you have offroad capable pods but the same exact light pod serves as a daily running light, amber front and red for rears. I am sold.
Maybe the other competitors have them too, i just haven’t stumbled upon them yet.
Have always wanted these. Curios to see if @Jmann
Got the noise figured out. And what’s the argument for ambers on the outside versus on the inside position?
I just went to their webpage and entered in my truck info and says invalid entry. Tried a few times, but looks like they don't make anything for the 21 F350... I like the look of baja better.
