Audio Input and Quality
So, many audio tracks are mixed by somebody. That "somebody" may decide to amplify certain tones for certain tracks. XM and Sirius have DJ's or "SatJ's" that produce content to their liking. CD's, USB, etc., can only give you what they got, if its some low bit stream, that's all they can give.
There are many tips on how to improve your sound quality from your mobile device. Now you too are a content producer.
@ccw thats a really good point, however I've strangely noticed that when I recently started wearing a new smart Galaxy watch 6...my Sync had more failures to connect or even getting frozen a few times. Almost like the Sync and Phone were getting maxed out on the bandwidth. I don't think its entirely true though that it uses Wifi for Sync on Android Auto though...maybe it does on Carplay? I say this because its very clear on Androids when Wifi is engaged and when its not... and if I kill my Bluetooth on my phone, it kills the Sync connection
Its entirely possible that Sync is using a mere Bluetooth 2.0 stack...which would be garbage compared to 6.0, the bandwidth on 6.0 for instance is higher, not just the range. I can easily walk 30 feet away from the truck and its still streaming my phones audio.
I'm wondering if someone's posted about this on the Blue Oval forums before?
Android Auto definitely uses WiFi Direct:
Wireless Android Auto works via a 5GHz Wi-Fi connection and requires both your car's head unit as well as your smartphone to support Wi-Fi Direct over the 5GHz frequency.
You can confirm this by going somewhere you have access to a WiFi network (likely your driveway or garage?), connecting your phone to that WiFi network, then connecting to wireless Android Auto. See if your phone shows that it's still connected to the WiFi network. If it is showing as connected, verify which network. If it's not showing as connected, try to reconnect to the initial network.
With my iPhone, while connected to wireless CarPlay it does not show it's connected to WiFi at all, but will prompt to disconnect from CarPlay if I tell it to connect to a WiFi network. It will also drop its connection to an existing wifi network, both functionally and in the UI, upon connecting to wireless CarPlay.
It's quite possible Bluetooth is being used for negotiating the connection, though. While poking around to confirm my statement, I learned iOS makes phone connections over Bluetooth while wireless CarPlay is connected, and thus a Bluetooth connection is still required.
Either of those, if Android Auto is doing that (likely), could result in another Bluetooth device messing with connection success even if WiFi is ultimately used for music data.
In my 2022 I don't use the phone for music files, but I do use the physical cable through the USB-C port. I find it's much easier to get CarPlay than trying to mess with wifi/bluetooth.
I also use wired CarPlay even though I have the wireless feature in my ‘22.
Same here. Far more reliable connection. No delayed response for media controls. Far less frequent phone overheating. Only connects when I want it to - so many times I was out messing with something on the truck, turning it on and off, and I have CarPlay connecting and disconnecting, music switching from my AirPods to the truck and back, a phone call switching from my AirPods to the truck and back.
So much nicer just plugging in my phone. Which I want to do anyways so it charges.
Yep, this. Hated phone calls going to the truck when I was nearby, or parking and getting out of the truck the annoying transfer of call back to the phone if I had one while I was driving.
So, I'm going to run a little experiment between Spotify and Tidal...since Tidal is always touted as having superior audio quality. I never gave it a second thought.
Just listening to similar tracks while on my Sony XM4's on my desktop, I can tell that Tidal SEEMS to sound better, but almost sounds like it has a preamp that turned up higher...
The company that did my audio install told me that the satellite radio being broadcast wasn’t very good audio quality, and recommended that if I wanted to listen to satellite radio, to do it through the app in my phone. Then, I asked if it was better audio to be wired or Bluetooth to the car. His assumption was wired, but he said to prove that, you’d have to do some high end audio testing to really see what, or how much, it was better, if his assumption was correct.
That being said, I mostly listen to stuff from my phone on Bluetooth, I didn’t enable wireless or wired CarPlay, and when I do listen to satellite radio, I just run it from the car. I think it all sounds fine. I have yet to test the satellite radio from my phone to compare though. Maybe I’ll do that today and see if it’s noticeably better.
But for this conversation, over-the-air music should definitely not sound better in the car than the audio coming from our phones, whether Bluetooth or wired. This is an interesting discussion.
So...Tidal vs Spotify = no noticeable differences. I noticed that on Spotify I had my Equalizer set to "Rock", but when I put it back to Flat, it sounded identical to Tidal. I think if your using Spotify, you just have to go into your settings and make sure Mobile Data and Wifi settings on quality are at Highest.
Unfortunately though - there's no change in the trucks sound...lol!
  • Like
Reactions: ccw
This is a bummer to read…waiting for MY24 production (just like most now!). I’m currently in Yukon XL and have zero complaints with the Bose system…now I’m thinking I’ll need to upgrade the stock system—all I really listen to is Spotify :sneaky:
@MJM_MWF Try listening to Satellite Radio vs your Spotify over bluetooth, I'd be interested to hear what you find out! Also, I hope your planning on getting an Carli pintop or e-venture suspension when your order comes in, or your in for a rude awakening on the ride quality from your Yukon! :D
Ha!!
Yes I am preparing for the ride changes…shifting gears from the XL as I now need a pickup
I will test the satellite radio via Bluetooth. Though thinking back, sound quality has been very consistent over that Bose stock radio.
The biggest change that I notice is when I go from standard FM station to when it picks up the HD signal on that same station, other than that, CD vs Blu ray vs Bluetooth I cannot differentiate quality.
I forgot that Spotify has different plans with different bitrates. We have the Premium Family subscription, which reportedly is 320kbps. Tidal HiFi and Master have higher bitrates but not on their entire catalog and not over cellular. When I was choosing a streaming service a couple of years ago I went with Spotify because the benefits of Tidal aren't relevant most of the time I'm streaming music, and Spotify has a bigger catalog. If I really want lossless audio I just play some vinyl on my much more expensive home stereo :)
Bit rate is usually the key as stated above. I don't stream audio from anyone. I use the FM radio and I have music on storage devices that I plug into one of the cheap FM devices (from China).
Figured I would throw in my 2 cents. I have experience this issue with my other vehicles (still waiting on my SD Tremor). I think it comes down to two possibilities, with the second being most likely:
1) The Ford Bluetooth in the receiving end, or the sending end is lower than version 4.2. This can have an impact on audio quality.
2) The source music being sent from your device is not high quality. If you are streaming at 32 or 64 Kbps, the quality will be low. If you are streaming at something like 320 Kbps MP3, or 320 Kbps AAC, then the quality will be significantly higher than the lower 32/64 bit rates.
The settings on your device (i.e. phone) may be set to store music compressed, and play at a lower bit rate, which is what you are streaming - so I think #2 is the most likely culprit.
Satellite however, is received at a higher quality (I believe Sirius is 256Kbps AAC), and your vehicle may have better tech built in to optimize quality at this rate as well. I am not sure on the tech part, but inherently the satellite signal is higher than how many people store music on their devices, or stream over a cell signal.
Cheers!
John
According to the Google, Sirius is only 64 or 128 kbps. That's pretty crappy. Maybe the Sirius radio just has a better preamp.
I found that the default bitrate is 256Kbps AAC and a max bitrate of 320Kbps, but transmitted over satellite is lower than 256Kbps. Hard to know for sure, and I expect it depends on location and such.
So, call me crazy...but it seems like the audio quality is better now that I've got the latest Sync 4 update, Rev 610. Not sure if its a placebo or not.
Hi there,
Here is an article you might find helpful:
https://www.slashgear.com/1392676/boost-audio-quality-android-auto/
I have several audio apps and Amazon Music has a very high quality output; however, YouTube music is louder. Tidal is decent but not worth the price; the sound is audibly lower. I have an aftermarket sound system (all speakers replaced, two 12 Kicker Comp R's on a 1200.1 amp and the Kicker key installed behind the deck running the speakers). There's also dynamat installed within the doors around the speakers. Some do the whole door.
Downloading your music to a USB drive is a very good option. It's a faster and easier connection, you'll notice no dimming as when you listen with Bluetooth and there's no messing your phone. There's too much going on when it comes to streaming: the connection, your phone's settings, the streaming source settings, etc. Same with watching movies: although streaming is much more convenient, I still prefer Blu-Ray with my home audio.
I hope this helps. I've played around with many outputs as well as music sources and it all comes down to what sounds the best to you. Be sure to check your phone's audio settings as well as the apps's audio settings. If you are using an Android device (mine is the Z Fold 4) go to: settings > sounds and vibrations > sound quality and effects > adapt sound and play with the frequencies. You might notice an increase of quality and sound.
Take care and have fun!
FWIW, both Bluetooth and Satellite are highly compressed. Don’t know which is more compressed, though.
I would absolutely expect a wired (e.g. USB) connection to have better quality than both wireless options.
You are correct in regards to the USB option over wireless option.
  • Like
Reactions: ccw
