ATF in diesel tank…
Vermonster
Moderator 🛠️
Tremor of the Month 🏆
Founding Member 📜
Meetup Organizer 🚧
GB Coordinator 📢
Vermont
2022 Iconic Silver F-350 6.7 Tremor Lariat
Some BMWs & a Ducati 748 Mono
Today I came across a video on the socials where an owner of an older 6.7 was traveling with his family. In the video they were at a fuel station and they happened to be towing a gooseneck with an old ford dually on it. But wait - there’s more…
The owner of this older 6.7, with 285K, was putting ATF in his fuel tank and swearing by it. Actually, his son was dumping it in while he filmed.
So I searched online and it seems to be a well known practice.
First - I have never heard of this.
Second - I’d never do this. There are supplements made to lube the fuel system in the same price range.
Lastly - I got to wondering….have any of you done this, or done this to an older rig? Or maybe you have heard of it, and it never traveled up here to New England.
I knew a mechanic who would run ATF in the engine for a short period off time when doing an oil change. He claimed the high detergent content would help clean the engine. This was when I was in college. Not sure about running it in a modern diesel fuel system. My first reaction is "yikes". :p
  • OP 🔹
  • Staff 🛡️
  • #3
So you've heard of it! It sounds like an urban legend. I agree - today is not the time to mess with the engines. Blowing out a Cp4 is not on anyone of our lists - and I would run fuel treatment meant for today's engine if you run anything.
I only run additives in the winter (Power Service), and not faithfully. What I do though - I change the filters often.
Been around a long long time. I know guys that do it in their 7.3s and 6.0s and frankly, I've done it in my 6.0. those fucking trucks would burn anything anywhere close to an oil. The theory much like @Modman below is that the detergents clean everything, and while yes they do they are abrasive and does not have the same lubricity characteristics as fuel. I have seen guys run it in their fuel and oil to help with some moderate stiction issues in the heui system but can also cause some damage to the injectors. I absolutely would not run that in a 6.7 injector with its overly tight tolerance that could lead to scoring of the bores. There's way better lubricity and cleaners now like XDP from optilube. Hell two stroke oil like tcw3 (iirc) is better option. Plus, if you ever happen to get pulled by DDS and they dip your tank good luck arguing it's not off-road diesel.
I've done this in my 6.0 a few times (as an engine flush) Stopped doing it when I swapped to Triax Fleet Supreme just like I stopped adding RevX to the oil too.
100% would not be adding that to a finicky 6.7s cp4 system. No telling what it would do to a dpf either. Plus there's just better shit to use now a days.
We used to do it in the early 80’s when I worked on trucks . Couple of the old timers would swear by it. They would also mix ATF with Safety clean solvent, dump it down the carb with the car reving till it dies let it sit half hour, sure cleaned the top end.
ATF has been used for a LONG time in diesel motors for whatever reason one would use.
If anyone feels that lucky to run ATF in their 6.7L....let them. Either it will work out or not. But then what will they blame....the CP4, their fuel??? They won't blame themselves for running ATF in their fuel.
Exactly this. Old school diesels were simple and would burn just about anything and run just fine.
Addin ATF to those engine didn't do any harm. It's also debatable if it did any good either.
It's an old school practice.
But diesel engines today are very different, much more complex and far more sensitive to crap in the fuel or bad fuel.
They are designed from the ground up to run on very clean straight diesel with low sulfur.
Adding ATF to a modern diesel would be a really dumb thing to do. Very bad for the emissions system.
I would not do this on a modern diesel, I realize that 6.7 had no emissions, but if it did you would definitely have some dpf issues, etc.
On a side note, when ulsd came out, I ran 2 stroke oil in my diesel fuel in my 5.9 cummins.
You ol' diesel boys sure have taught me a thing or three about old diesel trucks. I am surprised I had not ever heard of this, but I didn't grow up around diesels when I was younger.
wait till you find out about waste veggie oil or waste motor oil guys and them running that shit through their trucks.
Nothing like being behind a truck trying to figure out why you smell chinese
I remember the old guys in the truck shop talk about adding small amounts of gasoline to diesel fuel to improve fuel quality. These guys had all sorts of tricks they used on the old trucks.
I would not do that, especially in today's fuel systems, gasoline is significantly drier than diesel fuel (level of lubricity). I have heard that but never have done it in any of my diesel due to how cetane and octane are different ends of the spectrum. Plus IIRC gasoline and diesel have different specific gravities and don't like to mix together. Imagine getting a pocket of gasoline sucked through your fuel system and blasted into a cylinder.
I’d mix ATF with Jet-A in my old 6.4.. Worked very well 👍🏼
Was gonna mention the same thing. Used to be common practice with fuel samples. Dudes with old VW rabbits would snatch ‘em before we dumped em in the bowser or into other GSE.
Im genuinely surprised you havent heard of this. I heard people talking about this in my LMM days.
Granted, how would you if this forum is where you 'hear' most things?
Folks on here have a pretty tight tether to reality when it comes to taking care of their $90k truck and not risk it for a mpg increase comparable to installing an OmahaBravo Designs sticker.
My boy @Rodd187 can probably answer this. Hey Doc, have you ever had the ATF in your truck? 🤪
We used atf in diesel fuel
Used in semi trucks back in the day
But after the epa removed sulfur from fuel the fuel became dry so to speak
ATF became a no no burning
Injector/ nozzle tips became an issue in the early days of low sulfur fuel
For a while we put 30 wt non detergent oil in
Today we run diesel fuel born catalyst
( Pittsburgh power sells )
Or other brands
It’s pricey
The ATF is not welcome in or around my truck at any time.
Thought you might say that, Doc. Now where were we; oh yes, on our way to a game of faro...
