Anyone tried to order a 7.3L Gas 6.75' Box with GVWR >11,300?
UT & WA
‘22 7.3L F350
The order guide -- so far as I could find -- doesn't specify that the 11,500 GVWR is only for the 6.7L Diesel SRW, although the system defaults to that and 11,300 for the 7.3L Gas SRW. The online configurator still tries to kick you over to a diesel when you pick the 11,500 option, so it is clear the baseline GVWRs for the DIesel/Gas are indeed 11,500/11,300 respectively.
The order guide does note an 11,400 GVWR option (68L) but only for 7.3L with an 8' box.
Yet I have heard anecdotally on the infallible interwebs that a few 7.3L folks somehow got the 11,500 LB sticker. I have assumed this is just internet folklore perpetuated by misinformed posters with GVWR envy, but figured I'd check to see if anyone had actually gotten a dealer so special order a higher GVWR somehow.
If so, that would put me over 4,000 payload which would be fantastically perfect for my use. The GVWR games that manufacturers play are really annoying.
This is a comprehensive discussion we had a couple years back. Ordering a 7.3 gets you more load capacity despite it being a lower GVW and if you don't option the truck out with heavy items like a moon roof you can get near or over 4k cargo capacity if that's your goal.
I don't remember the exact number but I want to say the gas vs diesel gets you 800lbs more for gas with the same options selected.
What's your final goal? Cab over camper?
I'm pretty sure the 11500 is only the diesel. I have the 11300 gas per the sticker, but for some reason WA DOL put 12000 in the registration. Don't know where they got that number from.
My order sheet shows 11.3k GVWR.
-F350, 7.3, super crew, 6.75 box, 4.30 gears
To get to 11.5k you have to go 8' box.
To go higher you have to go diesel or dually.
What kind of payload numbers are 7.3 f250 without moonroof getting then? Not 3k-4k, right?
From what I’ve been able to gather, te diesel weighs about 800lbs more than gas, but the +200lbs in gvwr offsets it so with has you only get to more like a +600 in payload instead of the full +800.
If you get the 8’ bed gas, you get 11,400 lb gvwr to offset +100 lbs for the slightly heavier truck.
That me what’s annoying is the truck chasis itself is clearly good for a 11,500-on gvwr. They play games with different ratings to offset weights of some of the options to even things out.
Instead of making me delete the sunroof, why not just give me the extra arbitrary gvwr so I don’t have to? I assume the simple answer is so they can sell more diesels, because if they didn’t arbitrarily give them a higher gvwr then a fully-optioned 6.7 could actually dip under 3k payload on an F350... which would piss people off and potentially affect how often that is ordered. Seems artificial to me.
But yes, my goal is a cabover camper + an enclosed trailer with racecar and tools in it at around 9-10k lbs.
I have limited camper options that will stay under the wet weight. By the time you add winches and other bed accessories, plus extra fuel and a family... I’m over weight. Not by nearly as much as I would be on a diesel though. The extra 200lbs would be nice, given that they appear to be arbitrary.
So, I’m going to downsize the camper instead of taking options off the truck. As a daily driver, I’d rather have the options since the camper is weekend use only.
First-world problems, I know...
I'm looking at doing the same thing but my tow weights will likely never exceed 6k.
Lance 865 in a short bed is the camper I'm looking at. Long bed would open up a bunch of other campers.
And the superhitch setup is the way to go imo for towing with a slide in camper at the same time.
My '22 F250 Lariat without moonroof is just under 2,800 lb payload.
2865lbs for my 7.3 F250 Larait Tremor w/o moonroof (ultimate package, so tailgate step and all that crap).
I had the twin panel moonroof on my 18' F-150....opened it twice, didn't feel like it was worth it when I ordered my Tremor.
My 2021 F250 Lariat Ultimate diesel without moonroof has 2825 lb payload.
Mine is not a Tremor and only has 3 leaf springs.
Yes, so that proves the payload rating has nothing to do with the actual components on the truck. Mine has the 5 leaf pack with the Dana M275 rear axle, like any other Ford SRW F350, yet the number on the sticker matches a traditional F250. :unsure:
