Any issues carrying DEF while traveling with a TT
I pulled my Jeep to Moab and back, about 2500-3000 miles total. I filled the DEF at my local pump before I left (first fill) and I only remember filling it once on the trip. Still haven't needed to add anymore 2 months later. Heading to the Rubicon next week and will fill before I leave.
I wouldn't fuss with the jugs. Go to the truck lane at a truckstop if needed and fill it at the pump.
I guess it is possible it was not full. I remember looking at the menus and seeing 5000 miles remaining for DEF at one point, but I did not make it that far after I started towing.
What are others seeing as far as DEF consumption goes? 3000 miles, 5000 miles ??
I have filled my DEF up 3 times in just over 9000 miles. The first time I was almost out. The second time was a top off at service (probably half full). The third time just a few days ago I had 500 miles left when I filled it up.
I am taking a summer camping trip to Yellowstone and Mt Rushmore at the end of July where I will be driving 1700 miles (26 hours) each way. I will be towing an 8000 lb TT, so I know my truck will use more DEF than when I am not towing. I am considering carrying a 2.5 gallon box of DEF in case I run into a situation where I cannot find it on the road. I will try to fill up well before I get below 1/4 tank of DEF, but I am not sure how easy it will be to find while traveling.
1. Is there anything I should be aware of when carrying DEF in the back of my truck while towing a TT? I have a Bak Revolver, so it will be under the cover up near the cab.
2. Is there any particular brand of DEF I should consider? I saw a 2.5 Gallon box at Home Depot called Blue DEF for $12.50. (Good deal?)
Blue DEF
Any other thoughts or concerns would be appreciated.
Every gas station in the area carries DEF. I wouldn’t worry too much.
I'm on my 3rd tank in 4500 miles.
Fill up at truck stops. Every truck stop has it at the pump. The diesel prices are generally better as well.
We may run into each other. I have a similar itinerary (Yellowstone/Mt. Rushmore) around the same time.
From the various replies, it looks 2000-3000 miles is about average for DEF fill-ups. (Smindustries being the exception...) I am not sure why my in-dash menu said 5000 miles when I first got the truck, as that does not seem like the normal.
I have just over 3000 miles on mine and I have only filled it up the one time. It was not quite empty, but I wanted to find a station near my house that carries it at the pump. The diesel gas stations near my house do NOT carry DEF, so I had to go to one by the closest freeway which is 30 min away.
My in dash has read as high as 7000 miles until I started pulling my trailer.
I have 21k miles and it seems 4000-5000 miles has been pretty standard for me for a tank of DEF. Excessive towing would reduce this significantly (I only have about 6000 miles towing 4500 lbs)
I get 5000 on the dash but more like 7000 miles it doesn't use as much with out a load. I know mine was topped off since I always fill it at the pump and top it off.
I use Blue DEF in my Kenworth, whether it’s dead of winter or the summer heat it just sits either in the back of my pilot vehicle or on the neck of my trailer and I’ve never had it go “stale” or anything, seems like people really overthink it because it’s still fairly new but sometimes I’ll use 80 gallons in a week and I’ve never treated it like it’s anything special and also never had any issues with it.
As others have said it’s not hard to find, Walmart, Home Depot, any truck stop will carry it by the case so you will probably be safe without it if your cargo space is valuable to you but it’s not going to hurt anything sitting in the back of your truck especially if it’s under a cover.
If you go through it quickly there’s little chance of it going bad or stale. Heat and sunlight degrade def and if you have a bottle sitting for a year or more it’s not worth risking its use.
Def doesn’t just go bad all of a sudden but as it degrades the system compensates by using more of it until it reaches its limit. So it’s wasteful to keep a jug improperly stored for long periods of time.
Here is a site that talks about it.
I understand you are a Newby to diesel. No worries. We are here to help. Regular gas stations WILL NOT have Def available. That's why I wrote TRUCK STOPS. They will almost ALWAYS have it at the pump. Yes, it's a few cents more per gallon. So you may spend an extra dime for several gallons. Big Deal.
Get used to stopping at Truck Stops on your travels. There's a lot of them, they're more convenient with an RV, often have a pretty good diner or other fast food and easy in and out next to the interstate. Oh, an did I mention good fuel prices? And the diesel WILL be fresh and water free for the most part. Unlike the neighborhood gas station.
Advise given by someone who spent a lot of time on the road in big rigs.
Blue DEF
Well, with the amount of places to buy DEF in Wyoming (I live here) you will be fine, I promise.
IF your going to Yellowstone through the south gate, via Dubois, the gas stations in Dubois have it, You can find it in Riverton, and the gas station in Shoshoni, and Obviously Casper. I don't know your path to Mt Rushmore in the Black Hills, (I used to live there as well) Both truck stops in Rapid City have it at the pump. And every gas station has it in the box, anywhere you stop in the Black Hills.
Incidentally, if you are military or retired military and going to a national park, ask for the Military Access pass (at Yellowstone and Grand Teton National Park, just show your ID and your car gets in free). If you are a disabled vet you can ask for the Disabled Access pass which is a lifetime pass.
If you are not military, and want the National Park Pass (They are $80.00 and good at any National Park in the country for a year), stop at any BLM office. In Wyoming they are in Rock Springs, Rawlins, Lander, Worland, Buffalo, Newcastle, Casper, Kemmerer, Pinedale, and Cheyenne. I think they may also sell them at the Forest Service offices (I don't work there so don't know their locations).
I’m going to Yellowstone in a week or so. I can let you know what the DEF situation is. But like others have said, finding it shouldn’t be a problem.
West Yellowstone has it, Livingston has it.
The place between Grand Tetons and Yellowstone has it. Cody has it. Numerous stops along I-80....
We are camping on the western side at Yellowstone RV Campground at Mack’s Inn.
Thank you. I owned a 2000 Ford F-250 with the 7.3L diesel, but that was 20 years ago before DEF was required! I pulled a fifth wheel at the time and we loved “Big Red”, so I was comfortable going back to another F250 after spending years driving F150s and Raptors.
I am going to save myself the trouble and buy DEF along the way. I was planning to stop at truck stops anyway because the 36’ long TT will make it hard to get diesel anywhere else.
