I have purchased 100% of my DEF at the pump at truck stops so have been monitoring exactly what my mpg of DEF has been as I know how many gallons of DEF I purchase to fill the tank.
My usage so far has been without a trailer, 90% at highway speeds (80 mph out here) and I have averaged 836 mpg on 2 tanks of DEF. The DEF tank holds 7.5 gal so you should get at least 5,000 miles on a tank of DEF easy.
The main reason I buy my fuel at truck stops is the pumps are 3 times faster than auto diesel pumps. (I have the Atlas 55 gallon tank). Regular convenience stores are < 5 gpm and a truck stop pump is right at 15 gpm.
The DEF pump is right there by the fuel so easy to top off when needed while filling with fuel.
Most of the places/pumps that have DEF actually have a rectangluar blue sign that says DEF on it attached to the canopy above the pumps so you can tell before you even pull in. You can actually see the blue sign with DEF on it at Buc-ee's from the highway!
