Another full B&O sound system upgrade/replacement build!
If you replace just the sub can you still control the bass from the screen or is it a set it and forget it?
Might be a silly question but I haven’t replaced factory speakers in a truck in almost 20 years and all this new technology is hard to figure out
I don’t might the other speakers. Yeah they are not great but the sub is week and distorts in my ears.
BTW….i laughed my ass off at the sales guy when he told me the B&O system is “the exact same system in Lamborghinis”. I told him he was foolish. He was dead set believing it was. I told him are all Nike shoes the same in your opinion too!
If you're just looking to improve the bass, you can simply add a small box and amp using an LOC. (Line Output Converter). Soundsgoodstereo sells complete plug and play kits to do just that. Only thing you have to run is the ground and power wire for the amp.
I warn you though, once you change out to a better sub with no factory bass roll-off...you're going to want to improve the sound of your door speakers.
I did something similar with my f150. Little box that spliced into the wires behind my factory radio. Ran that to a small amp and built a center console box with a ten pointing out the back. Just removed the middle seat and custom built the box/console out of particle board and sprayed it with a can of bedliner. Wish I still could find the pictures I took while building it 🤦
HS nyone compared the 13.5" JL to running 3-10s? Wondering what sounds better.
The 13.5" is a shallow mount subwoofer. It's not going to be anywhere close to 10W6 with the properly sized box. The 13Tw52-2 that I'm running isn't going to rattle the teeth out of your mouth, but it still hits really well.
Your LOC should have a bass control knob that you can mount close to the drivers seat to adjust it on the fly.
The 13.5tw5 doesn't have the excursion of the tw3 series. Both are shallow mount but the tw5 is a little slightly shallower. The TW3 series has an excursion like their regular sub @ 15.2mm and the 13.5 is 11mm max. my 10TW3sD4s dig REALLY deep for a shallow mount. 3-10's will be louder and move more air than a single 13.5. You get 30" of cone vs 13.5". The TW3s are 400W RMS, the TW5 is 600 RMS. So, 3 TW3s running 400 RMS is 1200W RMS (just make sure to get the right voice coils to make it match your amp) vs 1 13.5 @ 600W RMS.
Ported is my favorite option but it depends on the music you listen to. Sealed is tighter sounding and plays pretty much any frequency. Ported is "tuned" to a certain frequency and is loudest at that frequency but will still play others very nicely as well but it's a boomier sound. Ported is 3db louder than a sealed box with the same sub and amp. I have a sound clip of mine but it's hard to tell anything from an iPhone mic, and you'd have to have good earbuds or something to hear it IF the mic did not distort out on the phone.
I have 3 10TW3s in the truck and 1 10TW3 in the 4Runner. Even that 1 in the 4Runner really surprised us all at the audio shop and it's perfect for my wife who didn't want overkill lol. Honestly it really shocked me too and I have been doing this forever. The box HAS to be made right though to get the best sound out of any sub.
Are you talking about the factory sub replaced? In which I mean taking the factory sub out and putting one back in the factory enclosure? I do not see a way to do that on the B&O Unleashed in the 23+ trucks since it is a weird 7x12'ish oval subwoofer. I don't know what the 22 and down models have? My 4Runner I can switch out to an 8" after market and use the factory box if I had wanted to. If you are talking about doing a new box, sub, and amp... most amps come with a bass knob. You would just need a LOC to tap into signal for the amp. You would control the sub with the bass knob if you did that.
1/28/24
Finally got some decent weather to start the install. Got the front and rear drivers side doors 95% done. Still waiting on the sound tiles and foam surrounds for the speakers. After looking at the pics, I realized that I installed the rear MTI door block off plate upside down. It covered the entire hole, with at least a 1/2" between the screws and the edge of the sheet metal...so I'm just going to leave it the way it is.
1/29/24
Got the entire passenger side nearly done today. Still missing the sound tiles and foam surrounds. Just the difference the sound deadening alone makes in the cab while driving is incredible. The new Focal's sound way better than stock, but the lack of volume still leaves a lot to be desired. The sub, amps, power wire, distribution block, sound tiles, and foam surrounds are all still in Fort Worth. I'll be heading back next weekend to grab everything and continue the project.
2/8/24
Got the rear cab sound treatment installed today and finished the amp rack. Going to reinstall the interior and amp rack tomorrow. Getting closer!View attachment 142694View attachment 142695View attachment 142696View attachment 142698View attachment 142791View attachment 142792View attachment 144003View attachment 144004View attachment 144005
Thanks so much for taking to time to post all this stuff. I am trying to piece together my own upgraded system for my 2024 F250. I was wondering how do you hook up the door speakers to the amp? Do you need a special integration harness, or does the PAC Amp Pro come with everything you need? I do not want to splice or cut any of the factory wires. Thanks in advance.
I bought connectors from Amazon that plug right into the factory Ford door harnesses. You just have to connect the + and - to the speakers. The PAC module hooks straight into the factory harnesses that plug into the factory amp. It turns those signals into a digital signal that is output through RCA jacks on the module. I didn’t cut or splice any wires with my setup. I can’t speak to your application since you have a newer truck. Shouldn’t be any different though.
Apologies for the ignorance here. I just added sound deadening to all 4 doors and replaced all 4 speakers with JL C2s. If I wanted to replace the factory amp (I assume it's powering the 4 doors speakers?) and add more power, I need a PAC unit or something similar and after market amp with some sort of wiring harness that connects everything back up so the speakers get more power?
That is correct. The PAC unit talks to the factory system and is needed to properly interface. It also handles the door chimes and navigation commands as well. Everything will be retained with the PAC unit. It comes with RCA connectors to seamlessly connect your amps to, as well as a plug and play harness for your speakers and amp remote wire. You just need to wire up the power and ground for your amps. It doesn’t get much easier.
Thanks! I think my research will continue. It's been 20+ years since I've done amp wiring and I guess I'm struggling mentally that I'm not connecting speaker wires to the amp itself.
I completely understand. It was a little overwhelming as well when I started building the amp rack. Once I had it all laid out though, I could see how I wanted it to all be put together and where things needed to be. Just take your time and plan ahead. It took me about two weeks from start to finish to complete everything. I did it while I was at work, several hours a day.
Just came across this video which I think helps my brain make the mental jump. Thought I would pass along in case others are struggling like I was.
Quick question for those who are likely more knowledgeable here. I'm considering if I should do two amps ( 1 for doors, 1 for sub) or a single amp to do both. I'm not looking for a full high end system but something over current b&o capabilities and a little more quality/thump. I've swapped the door speakers and factory sub for aftermarket already.
Considering for the two amp setup:
JL Audio JD400/4
JL Audio JD500/1
Considering for a single amp
Audio Control D-5.1300
I would like to keep the factory amp track and will likely run an amp pro interface. Also, likely swapping out factory sub box for a larger 10 behind rear seat setup in the future.
Appreciate any insight
JL Audio JD400/4
JL Audio JD500/1
100% two amps! I've always had two amps in any vehicle I've had. You'll thank me later 😁.
