for those of you that have put carli coils on your diesel tremor, how much softer do you feel the ride is (maybe) compared to stock?
thanks
thanks
I wonder if the softer ride has the same load carrying capacity as stock ? If so it’s a win win in my book
Currently in the middle of doing the rears. Did not do them on the last truck. Exactly what Carly says, Nicer ride, softer more progressive rear springs also airbags to level the load When towing or hauling. . We shall see.For the rears, depends on the setup but for the full progressive leafs replacement to get better ride quality, load capacity is reduced, but can be restored with something like airbags
Carly says yes. You can also buy HD springs from them with an added thousand pound payload.I wonder if the softer ride has the same load carrying capacity as stock ? If so it’s a win win in my book
I’ve got the full Carli kit going on in a couple weeks and will also report back.Currently in the middle of doing the rears. Did not do them on the last truck. Exactly what Carly says, Nicer ride, softer more progressive rear springs also airbags to level the load When towing or hauling. . We shall see.
Having to heavy inflated tires is almost as important as suspension if not more.Since I just dropped 3K on a brand new truck, MUCH better. Seriously though, small bump compliance is better. Also inflate your tires properly.
Piece of advice, when you get it done I'd suggest loading up the bed with ~1000lbs and beat on it a little bit before you let her give her assessment. The improvement right out the door is still pretty impressive vs. stock, but I'm approaching 20k miles on the full kit I had put on my 2021 last year, and even now it feels like it still continues to improve the more I drive it. Dan from Carli explained it in another thread, the pre-fatiguing process on the leaves (to keep them from settling over time) means they will be a little stiff until you really work them through their full range of travel with some weight on them. If you are going with a Pintop this will also help loosen up the shocks a little bit too.I’ve got the full Carli kit going on in a couple weeks and will also report back.
My wife hates the ride when seating in the back with the stock Tremor suspension.
I’ll know pretty quickly how the full progressive leafs work with her feedback
Good to know, I’ll probably have a 8K lbs boat on it the day after I pick it upPiece of advice, when you get it done I'd suggest loading up the bed with ~1000lbs and beat on it a little bit before you let her give her assessment. The improvement right out the door is still pretty impressive vs. stock, but I'm approaching 20k miles on the full kit I had put on my 2021 last year, and even now it feels like it still continues to improve the more I drive it. Dan from Carli explained it in another thread, the pre-fatiguing process on the leaves (to keep them from settling over time) means they will be a little stiff until you really work them through their full range of travel with some weight on them. If you are going with a Pintop this will also help loosen up the shocks a little bit too.
2nd this, went on a fishing trip with super rough roads for 200 miles immediately after. Incredible difference on drive home. Beat up the rear leaf springs and they break in, it's a must.Piece of advice, when you get it done I'd suggest loading up the bed with ~1000lbs and beat on it a little bit before you let her give her assessment. The improvement right out the door is still pretty impressive vs. stock, but I'm approaching 20k miles on the full kit I had put on my 2021 last year, and even now it feels like it still continues to improve the more I drive it. Dan from Carli explained it in another thread, the pre-fatiguing process on the leaves (to keep them from settling over time) means they will be a little stiff until you really work them through their full range of travel with some weight on them. If you are going with a Pintop this will also help loosen up the shocks a little bit too.
In a couple weeks I’ll have Tremor Diesel takeoff coils, leafs, and shocks availablethanks guys. i figured the carli coils were much better than stock. i have always been pleased with them.
here is the reason why I asked.
i have a gas truck, i want to run a carli kit. i am debating between their gas and diesel set-ups. their gas coils don't give as much front lift height as the diesel. my truck has 2.5-2.75" rake. the carli gas coils give 1-1.5" of lift. Carli even told me on the phone, some '24 trucks are not getting any lift on the tremor. I don't want to buy a kit and end not being happy with it. i don't want to run a spacer to get the added height
so then there is the debate about ride quality of diesel coils on the gas truck. there is no listed or discovered load rating on the Carli coils anywhere. however, they are softer than stock for each platform.
my truck has 4800 lb front coils on it. the equivlent diesel coils are 5200 lbs. 400lb difference. i imagine the since the carli coils are softer, they are probably in the 4600, 5000 range for eachi know some gas trucks (camper package, etc...) can come stock with 5200 coils
so my thought is to find a set of take-off tremor diesel coils (5200) and swap them on. run them and see how the ride is. if it is not bad, then i can assume the carli coils will be even better. this would be a cheap and easy test for me.
i am not concerned about the rear. i am going with the full replacement leafs. the leafs are the same on both platforms as are the rear replacement shocks.
So I towed my boat a few times now, and have about 600-650 miles on the Carli suspension.Piece of advice, when you get it done I'd suggest loading up the bed with ~1000lbs and beat on it a little bit before you let her give her assessment. The improvement right out the door is still pretty impressive vs. stock, but I'm approaching 20k miles on the full kit I had put on my 2021 last year, and even now it feels like it still continues to improve the more I drive it. Dan from Carli explained it in another thread, the pre-fatiguing process on the leaves (to keep them from settling over time) means they will be a little stiff until you really work them through their full range of travel with some weight on them. If you are going with a Pintop this will also help loosen up the shocks a little bit too.
