another Carli question... 🤦🏼
Your leafs will definitely "break in" and soften up to an extent, but if you overspec'd your springs, then how much gain youll see might be limited. Ive dont this once before and Im still trying to convince my self to rip the leafs off that vehicle and go with a lighter spring.
If you dont want to remove the springs you just installed (and I totally get that) you could also consider some useful mods to perform on the truck to add some weight. The easiest, most cost effective and practical one being an S&B 60 gallon tank. We run them on our truck (and sell them) and it will DEFINITELY add some weight.
What your make/model of boat? I don't think the bags would have been necessary for a anything sub 10,000lbs -- especially if you spec'd larger springs, but perhaps you or the shop knows about another trailer that Im not consdering.
Garrett
Yah boat definitely is ok for the full progressive springs, got the bags for camper I’m looking to buy…. Easier to just do it all at once then go back to the wifey to add more later 😂
Garrett
By the way, if anything ride quality wise can be resolved with weight, I like your idea and will be ordering. Unfortunately, it appears while the ride was ok for me in the city, and even better when I added weight (1000 lbs), the bouncing/rough ride on highway at higher speeds didn’t go away.
So, I need to figure out if this is “normal” or if something can be improved on
Just dropped off at Discount Tire for a road balance. The pulse/vibration in the accelerator pedal was also starting to get more pronounced.
Having them swap the front wheels with open caps so I can get access to the manual hubs. I’ll at least be able to eliminate two items this evening, tire balance and/or the hubs.
If no improvement it will go back to the shop for them to look at things again.
Sounds like you should have gotten an F-150
The wheels and tires were pretty unbalanced based and rides much better. No more vibration in the pedal. Still bounces, but I’ll just continue to let it work in and play around with tire pressure
