Air Bag Position
mpd2434
Tremor Buff
NJ
First Responder
Police
2025 F250 Tremor
I just had these installed by a local shop along with PMF Suspension 2" blocks. I currently have 10lbs of air in each bag. The bags seem, to me at least, to be slightly off center and on a slight angle. Is this normal? If not will this cause any issues once I add air to a heavy load?
Airbags are supposed to be mounted perfectly vertical, centered with brackets. Yours definitely look off center. I cannot tell you whether or not this will cause an issue, but I personally would not want to take a corner with a heavy load on those airbags.
Interested to know what others think.
Is that a spacer under the bag or a cradle? If it’s a cradle it’s upside down. Bags rest inside the cradle and help center the bag.
That's what I thought. I'm wondering if the PMF 2" blocks are the reason for it being off center, they were alot wider than the OEM blocks that came out of it.
Honestly I don't know if it is or not. I just took those pics last night. I was removing my rear center caps from my rear wheels when I noticed the uneven bags.
Here is a picture of an airbag in the cradle. If you have a spacer to fill the gap from the lift the bag will be or should be bolted to it. And should stay in the center. The cradle does not bolt to the bag itself. It’s so you don’t loose downward travel or pull a bag apart.
I wont claim to be an expert on this, but i have ordered a fair amount of parts from PMF. When you order the block you have the option to add air bag supports. I would highly recommend doing this with your setup since the PMF blocks with the u bolt pass through i believe are wider than most. I think these are airlift bags and the way they install to the block is horrendous with their mounting system, and it is meant for oem style blocks. If you add the PMF block WITH the air bag support it will be a much cleaner install and it gives you a mounting plate where you can drill the holes yourself for the bag (or the cradle) to be perfectly aligned. I installed 2" blocks in my dads truck that had airlift bags with the included PMF mount and it was perfectly aligned.
Here is where i think yours are wider than most OEM style blocks, which is why its being pushed out a bit:
Hope this helps!!
I just watched an installation video where that black spacer is bolted to the bottom bracket just like the pics I sent so I assume that it is correct.
Hope this helps!!
I already have the PMF 2" blocks installed on it. I specifically contacted them about adding air bags and if I needed their air bag mounts with a single air bag (per side) setup such as Air Lift, Retrue, etc. or if I could just order the blocks with the tang. They said their mount gives more of a mounting surface for the bag but these types of kits will work with there mount or the tang. So I opted to just order the blocks with the tang. It looks like (from pics) the extra mounting surface of their mounts is installed further toward the center of the axle anyway which would make it more off center than it is now.
Their mount has a flat surface directly next to the u bolt pass through, which will give you much better chances of getting these bags aligned. I know because i have done a very similar install on my dads 2019 with airlift bags. I feel like your current setup has a massive gap between the block and where the bag is mounted:
See in their diagram how flush this sits to the outside of the u bolt hole? It would make it so your bag would be right where it needs to be based on your picture above?
That’s a cool mounting solution.
Yea I see what your talking about, I'm sure that's probably my issue, I'll check when I get home from work. If it is I hope there is some adjustmant in it to move them over. Like I said I actually talked to a rep and they said for my application either with or without their air bag mount it would work fine for my kit. I have a call into my mechanic about the issue also but waiting for a call back.
Thats a bummer they said it would still work. PMF has been very knowledgable in my experience but im surprised they didnt just recommend spending the little bit extra for their custom fit mount with their block.
Maybe they would be willing to offer you a discount on replacing it given your situation.
I think your three options to get your problem fixed though would be to:
1. chop off your u bolt alignment holes on the PMF 2" block and then you can likely get everything a little more flush to where it needs to be.
2. Re order the block with the attachment, more expensive but the proper way
3. Find an alternative block that doesnt have those alignment holes sticking out that you can order and keep your current bag mounting solution and reinstall
Based on what i have seen though, the PMF air bag bracket is by far the best/cleanest install without all the nonsense additional cross bolts and weird mounting that the airlift system has.
You were correct and this is my issue. I checked it as soon as I got home and those ears that the ubolts go through are protruding out. The air bag mounts are tight up against them so there is no way to adjust them. I even checked to see if the top of the mount could be adjusted but that's a no also. I beleive your three options are my only way to get this right. I love the quality of the PMF blocks but I was surprised when they were delivered at the width of them compared to the stock ones. Stock thickness blocks would work fine.
Well now I'm really pissed. I just got off the phone with PMF Suspensions after speaking to a tech. I explained the problem and that I specifically called them prior to purchasing their blocks to make sure the blocks with the tangs would work with inboard airbags like the Air Lift and Retrue. (which they said they would). Now this tech. said that the blocks with the tangs won't work with inboard air bags so I basically just pissed away the money for the blocks and the $900 I paid to have everything installed. Because I didn't remember the name of the original tech. I spoke to back in March, the best they can do is give me 25% off new blocks with the air bag mounts, thanks alot PMF.
A little update if anyone is interested. Yesterday after work I disassebled the passenger side air bag mount and removed the axle u-bolts. It was tight but I was able to get a hand held recipricating saw in there and cut off the ears/tabs that the u-bolts go through on the PMF blocks. After doing this I spray painted the bare metal and reinstalled everything. The extra space created by removing the tabs allowed the lower air bag mount to move approx. 3/4" over toward the wheel which aligned the lower air bag mount with the upper so now the bag is perfectly aligned. Finishing up the driver's side today after work.
Sounds like a relatively happy ending. Still was wronged by PMF but a decent solution so now everything is aligned properly. Glad it worked out.
Thanks, just finished up, about 4 hours total but at least I got it to work. It would have been so easy to cut them on my bandsaw out of the vehicle but I didn't want to completely remove everything. Even if PMF gave me the new blocks for free I wouldn't have wanted to wait for them to make and ship them. I was surprised at their response to me not taking any responsibilty but it's done and I'm moving on. Thanks again for the help.
