Avslash
- Joined
- Oct 20, 2021
- Messages
- 415
- Reaction Points
- 957
- Location
- The Lonestar State
- Current Ride
- 2022 KR Tremor
Bought my 2022 off the lot, and literally the only option left off was the factory upfitters. No problem, dealer agreed to order parts for me to install as part of the deal.
Got the parts. Replaced the overhead console for unit with the switches, ran the new wire over the headliner and plugged into the connector at the A-pillar, added the fuse block under the hood and connected to the prewire harness and the battery terminal block.
All seemed good. Switches light up when moved to on position.
However, no power coming from any of the pigtails under the hood when switches are on.
I have checked fuse 57 and fuse 22 under the hood and in cab respectively. I have pulled fuses from upfitter fuse block and verified there is power at each fuse. I have checked each fuse with ohm meter and all show zero ohms resistance. I have checked and there is power at the 20a+, and 20A+ STR wires that are part of the upfitter bundle so the upfitter fuse block is definitely getting power, but all 6 of the upfitter pigtails are dead.
Anyone have any thoughts on what to check next? I am fresh out of ideas now.
Thanks
Thanks
