A little jingle
surfscottydog
Tremor Fanatic
Santa Cruz California
Handsome Jack. 2022, F250 Tremor with Four Wheel camper, Fleet, White Knuckle rock sliders, Buckstop rear bumper. All the bells and whistle‘s that I might need
Subaru Outback
So I have noticed, when I’m driving at a low speed, somewhere between 25 and 30 and go over some small bumps in the roadway, I sometimes hear a jingle coming from underneath the truck. It sort of sounds like a small chain jingling. At home I will crawl under it and knock around and try to duplicate the noise, but I can’t locate it. Anyone else have this? It doesn’t seem like it’s a problem, but I can’t figure it out
It's your hitch 😉🤣🤣
Rock above/in the spare tire?
Rock in some other cavity?
It's your hitch 😉🤣🤣
Different hitch from stock, and no chains dangling. The spare is up on the back bumper so not that. Doesn’t sound like a rock, sort of, sounds more metallic. Problem is, no one will let me drag them around underneath so it’s hard to locate the noise
Check the heat shield above the exhaust. I remember reading about the 7.3s having a loose shield. It may have a harmonic resonance at lower speeds.
Agreed. Heat shield are always the first check for me. Usually on any prior truck or Subaru especially the welds break and they start to rattle at a certain harmonic resonance. An easy check is to get large radiator clamps and strap one around the heat shield and see if the noise stops.
I would do it. YOLO 😎
100% check your tranny heat shield.
They are known to shear around the fastener portion. Theyll look still fastened but will be loose. Likely why one of mine was missing when i bought the truck. push/pry on them a little. wouldnt surprise ms if this is your culprit.
I have the same thing, 19 and 24 sounds like change or a small chain. Never bothered me enough to track it down.
Change in your pocket
I was thinking the same thing, coin money is all we have left after buying a Tremor… and whiskey.
Shoot, I don’t even drink anymore
Me neither, but I remembered it and where better to bring it up than here
My truck jingles every night. I'd upload a video but I value my membership 🤪.
I had to sleep on this for a little bit. Did you inspect the fuel tank skid plate?
