3D Printed Oil Change Funnel
I’ll try get to the Ford dealer this afternoon see if it works on the 6.7. Sure he’d be willing to make one for it.
Definitely other options out there but sure is cool supporting someone making a little business out printing these right here in the good ole USA.
Make it with a longer taller neck for the 6.7 trucks too.
I’ve got a 2022 GT500 and am a member on FordGT500.com forum. A member there 3D prints these awesome funnels for 20-22 GT500s. I was changing the oil on the tremor and noticed the oil fill caps look similar and turns out the funnel works on the 7.3. If anyone has interest in purchasing let me know and I’ll loop the guy who makes them in. Insert them into the fill neck and turn 45 degrees and the funnel locks in vertically. Very convenient.
Edit: Seller is Jon, email is [email protected]. Send him an email and he’ll get you squared away. Cost is $55 shipped.
any thoughts on turning that into a supersnake ?
@ColeH I have one of your GT500 funnel and drain extension. Great products and even better person!! Do you have one for the 6.7L?
Another one that will work with the 6.7 that is in stock:
Oil Funnel
They all seem to be the same
This is the ticket for a 6.7, the 6.7 fill is vertically straight. The funnel that is the subject here is at an angle to better adapt to a angular application.
Negative. Supersnake is just a 5.0L GT Mustang that rolls off the assembly line and is then converted by Shelby American. VIN still reads as a Mustang GT. GT500 is built at a Ford plant and comes off the assembly line and to a dealership as a Shelby GT500 with supercharged 5.2L Predator engine.
Now the King of the Road edition requires a 2020-2022 GT500 donor car. Thats going to be something else.
This. I use the same $8 funnel. I just don't know why you need $50+ or $100+ funnel to fill the oil?
To each there own….you can use that logic on why people swap out a completely new suspension for a Cari system but they do….more power to them….
Not quite, the logic is very different....that Carli system can make a rather noticeable improvement in ride and suspension performance, as well as a change in height that may be wanted. Asking why a $50-100 funnel, that does not perform any different than the $8 funnel, is necessary, is a very different and fair question. The benifit of the 7.3l funnel is somewhat obvious but on the 6.7l it's harder to understand. Do you have some logical reasons to why a $50-100 funnel may be better for use on the 6.7l vs the $8 funnel?
Thanks for the shout out @ColeH , and to the few of you that have reached out thus far to place an order. I’m Jon, the guy who 3D prints oil funnels and oil filter guides for a variety of fords.
Since no one knows me on this forum I figured I’d introduce myself and tell you how I got started 3D printing gear. While on the phone with a friend (also a GT350 owner) , changing oil in my 350 after a track weekend and drinking bourbon… I was complaining about how much of a pain it is to remove the gt350’s oil filter without creating a giant mess on the belly pan. (Take my word for it… it sucks.) Knowing I had a 3D printer at home, my friend suggested I design a part to help guide the oil towards the wheel well and away from the belly pan. 17 prototypes later, I had something kickass that does exactly what it’s supposed to do. Naturally my friend wanted one for himself, and after he had a chance to use his, he suggested I started selling them to other forum members. So I did.
After a few oil changes (I do about 8 a year on that car due to tracking it) I was tired of having to hold my oil adding funnel with one hand to keep it from moving while I poured all 10 quarts in. I went on Amazon to order a better funnel when I remembered I had a 3D printer in the other room, so I might as well make a funnel I could lock into place.
That was 11 months ago, and both printers have been printing almost nonstop since then in order to fill orders. To date, my 4 different funnel designs work on almost every ford engine since the late 90’s and I have something like 400 customers.
Is it for everyone?…. No, absolutely not. But does it make life easier by freeing up a hand when you’re changing you own oil? You bet it does!
In closing, if you’re looking for an oil funnel that’ll take oil as fast as you can give it and frees up a beer holding hand, I’ve got just the product for you!!
-Jon
P.S. - I’m guessing one of my funnels will fit the 6.7. If someone would be so kind as to send a few pics of the oil cap when installed on the engine, then a few pictures of the cap when not installed I can confirm my assumption. Heck, I might even need a beta tester if anyone’s interested…
I’ll be the first to tell you my caliper skills are not the best. I tried to get some measurements of its surroundings as well.
I would use one of these. Is the funnel big enough to hold an upside down gallon oil jug?
I got the test for model today. Below are pics of it. My thoughts are, this thing is great. It’s an exact fit complete with an o-ring for no spillage.
It has a nice wide base for 100% upright storage. This has always annoyed me having a funnel leak as it sat on its side. It also has a lid to keep dirt and grime out during storage.
I did suggest two changes which are it has a 12 degree tilt due to the filler neck and ideally it would hold up our 1 or 1.25 gallon jugs.
The funnel will take oil as fast as you can pour it, and I’m a little concerned about the weight from a full gallon would have on the funnel to receiver connection. I’m sure it’d hold up the first, second and third time… I’m worried about fatigue after the 40’th time.
View attachment 60931View attachment 60932View attachment 60933
Thanks again for assisting with the test fit for the 6.7, I’m glad it fits. The only thing I could use help on is figuring out where the 12 degree tilt needs to go towards. It’s hard to tell exactly because it’s a square funnel. Could you maybe mark which side is facing the front of the truck, then send a pic showing the bottom on the funnel with the mark visible on the top part? Not sure if that makes sense, but my only way to orient direction of the square funnel is to use the twist mechanism at the bottom.
Do you see the 12 degree angle as a detriment to using the funnel? The reason I ask is, I hate to spend the time and effort to redesign a funnel to add the 12 degrees if I’m only going to sell 5 (if in fact the 12 degrees would be detrimental.)
You'll probably sell 100-200, at least, knowing this forum.
