Rotella sometimes emits a burning oil smell for me. There is a reason they call it Rosmella. I use Valvoline premium blue
Keep in mind the multi-viscosity oils start out as the lower base. In other words 5W-30 and 5W-40 both start with SAE 5 "weight" oil and then have an additive package so they perform like a heavier oil in warmer temps.5-30 vs 5-40 or 10-30 vs 15-40. Or something along those lines
This is the best recommendation as far as I am concerned!Ford recommends 10w30 for conventional oil and 5w40 for synthetic
Same here.I always use 5w40 Rotella.
I’ve found it takes a bit more than 13 to fill my 2022.I know OP is asking for 2024, but in case anyone reading this in the future, earlier years are different... 2022 6.7L is 13qt.
Funny this topic was raised.
I had my first oil change this week. I live in a mild winter area so I don't necessarily need 10w-30.
I bought my Wix XP filter and 4 gallons of Motorcraft Full Syn 10w-40. I don't have an oil drain pan that will hold the 15 qts this beast uses yet. My 15 F-250 used 13 qts. So I went to an oil change store in town that I trust. The gentlemen instantly told me that if I still have warranty he will not put that oil in the truck. He showed me the oil cap that says 10w-30 which I'm well aware of. I had to pull up the owners manual and show him that it's ok.
It is awesome that he looks out for his customers like that but funny how I had to prove it for him to proceed.
Oh, you are right. It is 15w-40 but it is definitely diesel. They do come in gallons.
OMG...Wow!
I'm sorry typed 10w-40 instead of 15w-40.
I'm sorry I said gallon instead of 1.25 gallon.
I'm sorry I put Full Syn instead of Conventional.
I was simply telling a story about my oil change.
I'll make sure to fact check every word in my next post.
Went to a different dealership today, I’ve been getting 10w30 since owning the truck for the last 17.K miles. This dealer put in 15W40, and the Ford code on the receipt was XO-15w40-BSD
Can’t seem to find much info, but it is a motorcraft product based on the receipt. Maybe BSD means bulk/barrel?
You can run 10W30 to improve fuel mileage but you may as well be driving a F150 then.
