4 sets of end caps are spoken for, will send out as soon as I get them, supposed to be friday.
Thank you! Hope I made the cut4 sets of end caps are spoken for, will send out as soon as I get them, supposed to be friday.
YES, you did make the cut, but I need your mailing address. If you already sent I missed it!Thank you! Hope I made the cut![]()
Yes. Torklift TieDowns use the Hitch to mount the Rear Brackets.Are those openings used for the rearward slide-in camper anchor points?
Sardonic take, but highly accurate.You should start a side-hustle business engraving skulls and American flags into these things.
Fellow forum members will go nuts for them.
Thanks!![]()
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.www.mcmaster.com
Try rotating the cap 90º. Measuring the cap with a caliper, one side seems smaller then the other. One side of the Ford square tube may be different in dimension slightly causing the loose fit.Mine arrived today as well. Thank you Lunch Box!
Did a quick test fit and the driver's side fits good, but the pax side is fairly loose. Will put them in this weekend with a little bit of whatever sticky crap I can find in my garage to try and ensure I don't leave them in the middle of the road somewhere.
Thanks again!
You are welcome. Are you sure they seated properly. I thought the same thing and found they were not all the way in on all 4 corners. I then used a rubber Mallett to fully seat them. Both are super snugg now.Mine arrived today as well. Thank you Lunch Box!
Thanks again!
Make sure they are seated properly. Use a rubber mallet to hammer in all four corners. I did this, they are totally snug.Mine arrived today as well. Thank you Lunch Box!
Thanks again!
Thank you again for the capsYou are welcome. Are you sure they seated properly. I thought the same thing and found they were not all the way in on all 4 corners. I then used a rubber Mallett to fully seat them. Both are super snugg now.
Sorry for the double response, didn't think the first one postec!You are welcome. Are you sure they seated properly. I thought the same thing and found they were not all the way in on all 4 corners. I then used a rubber Mallett to fully seat them. Both are super snugg now.
Thanks. Tried that for both sides. It helped on the driver's side, but not the pax.Try rotating the cap 90º. Measuring the cap with a caliper, one side seems smaller then the other. One side of the Ford square tube may be different in dimension slightly causing the loose fit.
Thanks. Will try the mallet before the sticky crap ?You are welcome. Are you sure they seated properly. I thought the same thing and found they were not all the way in on all 4 corners. I then used a rubber Mallett to fully seat them. Both are super snugg now.
Please report back if it worked!Thanks. Will try the mallet before the sticky crap ?
