The loud fan noise is definitely attributed to the summer temperatures.
Lol. Me too. We finally had a hot day yesterday and the fan came on. I was like big rig coming through! Look at me.Interesting. Mine does this occasionally, it only when it’s like 115 degrees outside so I figured it was just due to being insanely hot outside. I don’t mind it though - I think it sounds mean. Haha
I feel the same as you on the sound!Interesting. Mine does this occasionally, it only when it’s like 115 degrees outside so I figured it was just due to being insanely hot outside. I don’t mind it though - I think it sounds mean. Haha
I originally thought that too, but if that is the case, why is it starting to do it right after startup when everything internally is 100 degrees or less, and the outside temperature is in the 60’s? Doesn’t seem to me like the right scenario for the fan to be needed. I’m going with @BroncoHooves opinion that it’s a bad fan clutch. It never acted like this the past two summers. I’ll know more next week.The loud fan noise is definitely attributed to the summer temperatures.
Thanks for the reply. I’m assuming that I’m not doing any damage to anything by driving it around in the meantime?The tornado garbage truck sound is from a bad fan clutch. I’m pretty sure they still haven’t revised the part yet though, so the sound is likely to come back.
Correct. Mine has done it since I got the truck basically in its first summer. Have 22K miles now.Thanks for the reply. I’m assuming that I’m not doing any damage to anything by driving it around in the meantime?
Mine will do this on and off sometimes.From my experience with the engine fan, is if you start it and drive it immediately, especailly after sitting, it brings on the fan briefly, even though the engine is cold. Normally happens when the truck sits overnight. Even my work truck, with the 6.2l gas engine does the same thing. This fan clutches are controlled by the computer, I am no engineer, but I believe when the truck sits for awhile it self checks the fan clutch to make sure it works.
Can anyone chime in yet who had this done of the daily driving differences?
No, depending which modules are flashed there's a chance if they have to reload asbuilt data but typically not.Does this reflash erase all forscan changes?
I just dropped mine off for the recall “repair”. I’ll report back on driving this next week. I’ll be towing 8k lbs on Monday, so that should be an interesting test.Bump
Please report back on DEF usage, and fuel economy before and after.I just dropped mine off for the recall “repair”. I’ll report back on driving this next week. I’ll be towing 8k lbs on Monday, so that should be an interesting test.
