2025 front oval
Did BFN receive the proper front ovals?
The one I received shows how undistinguishable it really is.
Hell yeah if that’s one that he molded looks good how does it look to you in person I mean you’re the one that’s got your hands on it
Nice so you had no issues mounting your camera? That was one of my concerns trying to use a “24” blackout oval wasn’t sure if the camera mount would be the same without the washer being there
I'm sure they didn't change anything...just took away the washer.
I am in the process of changing all my ovals and badging and grill with BFN. So far, everything has been top-notch. I attached a picture of the front & rear ovals and the side badges. We're doing everything in Agate black and Carbonized grey. I have the Limited grill to replace the Lariat grill. The 02 thin bars in the limited grill are painted carbonized grey. At the moment, I can't show a picture of the grill; it is upside down on a blanket with Raptor lights and wires. I will update you after installation. I am waiting on the install as the truck will be going in on Tuesday for a Full Carli 3.5 Backcountry level. As I get closer to PPF & ceramic work, I will install the badges and grill. :cool:
I still do not have my truck yet. It will hopefully deliver this week. That said, the four holes are there which are used by the bracket to mount the camera (and nozzle if equipped).
In my discussion with BFN, I was sure to tell them it was for a 2025 and they guarantee fitment.
I was surprised with how quickly they arrived for my 2025 F250. Not sure what year emblems your waiting for, but they are worth the wait.
How hard was it to swap the front and rear ovals? What was the process?
Very easy.
Front: Remove all the push pins of the top cover. Then take the bolts out on the top of the grill. Next remove the small access panel on each bottom side of the grill to get to the hidden bolts (one per side). Now pull the grill off to release all the clips and swap the oval.
I purposely didn’t unplug the camera so I wouldn’t have to recalibrate the 360 camera system. Not sure if it always has to be done, but unplugging it may force a recalibration. Just unscrew the camera assembly from the grill as it is pulled forward, then let it hang while you take the grill to the bench to swap the ovals. Then reverse to install.
Rear: Place painters tape around the border of the oval, then use a plastic trim removal tool to pop it off. There are two clips and some double sided tape.
Here are the instruction from the factory service manual. Again, I did as I described above, and only used the instructions for guidance.
Thanks for the detailed response.
That looks Amazing!
Why not just take your emblem to a body shop and have it paint matched(or whatever color scheme you want )... probably cheaper than buying a whole emblem
If you don’t mind me asking what can one expect to fork out for this? I know price will vary based on shop/location but curious.
Most shops are not going to want to put the time into it you have to completely disassemble the ovals to properly prep and paint them and that consist of removing plastic weld rivets then having to plastic weld everything back together after paint
I disagree
Disassembly is literal minutes with a pair of sharp side cutters, or flush cutters. You only need remove the mushroomed portion and they come right apart
And they do not get plastic welded back together, although I guess you could but it's unnecessary. you can use epoxy or the shop will use a quick set 2 part adhesive
I do my own tear down and reassembly as it is my friends body shop and I do work for him at times. But he does hundreds of color match emblems and other parts for customers.
As for price I can't comment on it, as my situation is different.
Hey there.. one of the members here sent me this link. Just wanna say thank you for the kind words and support.
Robbie (BFN)
Welcome aboard Robbie 👍😎
Yuuuup, I caved to Cux211's peer pressure and ordered a custom oval through Robbie @ BFN as well. I think it was Cux211 who dub the oem oval as the "giant chrome cancer" or something like that??? Lol, and once it was out there that's all I could notice....just how bad the stock oval stuck out like a sore thumb. Anyway, I can't wait to get my new Oval from BFN. I'm not particularly looking forward to ripping the grill off but doing so will also give me the opportunity to run some black mesh material in front of the radiator. The bugs up here are BRUTAL during the summer months.
Sorry about that lol, yeah it drove me nuts I would love to find the person at ford responsible for that decision. The grills on these new trucks aren’t bad the only thing I would add is be careful with the bottom 4 clips just above the bumper you’re kinda blind and in my case I got everything back together then was jamming my fingers in there to check to find I missed 1 out of the 4 so god damn it I had to pull everything apart again so once the grill is back on but before you put all the bolts and plastic buttons and top tray back make sure all 4 of those bottom clips are in right
