I have a 2022 Platinum Tremor and I have wet carpet under my Weather Tech floor mat on the drivers side foot well. I checked the firewall and all grommets are intact and dont leak. So no water is coming down the inside of the firewall on to the mat or on to the carpet. I checked the rear cab vents and they were loose. I adjusted them and ensured the clips were properly installed then added some adhesive so they stay sealed. I removed the rear subwoofer and insulation padding and was able to access them that way. There was no evidence of leaks. I then checked the electrical tunnel that runs the entire length of the cab. Bone dry. I then checked the drivers side door card moisture barrier between the metal part of the door and the door card. The moisture barrier is installed properly. No leaks there. I have a sunroof and cab lights. They are also clear of any obstructions and no leaks are coming out of the A-pillar handle. I also checked the A/C drain. It has the correct fitting on it and I didnt give this any thought because it was on the passenger side and the passenger side is completely dry. I did see that some other guy had said that there could be floor panel rubber/plastic access covers that came loose on the drivers side under the carpet. I havent torn up my carpet yet, but I wanted to know if there was actually rubber/plastics plugs under the driver side floor carpet. Anyone know for sure? Here's the real mystery- my carpet is wet when it isn't even raining or have water on the road. It only gets wet when I go through the car wash and it does do the undercarriage wash. So I am thinking that the water is being forced up through the floor pan some where and if there are plastic access covers in there, then that could be the source of my issue because only the bottom of my footwell is wet. Like its wet on the bottom and then on the side of the tunnel its wet up two inches from the bottom.Is anyone having water in there driver floor board? Got in my 2022 today and the mat had a lot of water on it
