Riverjackson
- Joined
- Sep 16, 2021
- Messages
- 5
- Reaction Points
- 3
- Location
- Myrtle Beach sc
- Current Ride
- 2022 f250 tremor
Is anyone having water in there driver floor board? Got in my 2022 today and the mat had a lot of water on it
I just gave mine her first bath today and have also been in a lot of rain recently. Luckily, so far no issues.Is anyone having water in there driver floor board? Got in my 2022 today and the mat had a lot of water on it
My 2022 F350 king ranch is leaking water onto driver floor board. So far Ford dealer hasn’t figured out why! FrustratingNo moonroof, I have appt at the dealership Monday morning
My 2022 F350 king ranch is leaking water onto driver floor board. So far Ford dealer hasn’t figured out why! FrustratingMaybe this thread will help...
Water Intrusion
Hello Family, first post for me but have learned a lot from all that you post. Was wondering if any of you have had water intrusion issues with your Tremor? We just started having our Pacific Northwest rain for the past few weeks and I noticed that brutal smell when I opened the door. That led...www.fordtremor.com
Water Intrusion
Same thing happened to my 2020, and a few others. Problem is a damaged cab vent, they have to remove the bed to fix it.Is anyone having water in there driver floor board? Got in my 2022 today and the mat had a lot of water on it
It took a couple trips to my dealer before they figured it out. Have them check the cab vents.My 2022 F350 king ranch is leaking water onto driver floor board. So far Ford dealer hasn’t figured out why! Frustrating
There’s a way to install the vents without removing the bed. PTT Arod showed in a video.Same thing happened to my 2020, and a few others. Problem is a damaged cab vent, they have to remove the bed to fix it.
Mine is leaking thru the lights on the cab. It's been in 5 times so far. Next appointment is MondayIs anyone having water in there driver floor board? Got in my 2022 today and the mat had a lot of water on it
Yes, I was planning on some EPDM rubber hose to friction fit between the bed and the cab to prevent water from going down this way! Haven't sized up the hose dimensions or ordered it yet.Has anyone considered adding some rubber tubing above the vents in the spot i’m pointing out in my picture. As a preventive measure. That way water would go around the vents and not hit them from above directly. I was looking for a right size rubber tube on amazon, measured that it has to be somewhere between 1/2 and maybe 5/8. Wonder if anyone beat me to this idea.
Thanks same here. Seems like a cheap preventative measure that would divert water from the vents, thats really the goal. I found some tubing an amazon but didnt save the link. It was flexible and close to 3/4 inch i recall. If you find one that works well first, please share the link.Yes, I was planning on some EPDM rubber hose to friction fit between the bed and the cab to prevent water from going down this way! Haven't sized up the hose dimensions or ordered it yet.
