2022 Water leak
I will take a chunk! Added benefit for us northern climate folks... it will help to minimize snow packing between the cab and bed during the Winter!
@Modman Will reach out to you on Monday via PM when the piece comes in.
I have two more pieces of Neoprene available if anyone wants to buy.
I should get one of these from you. It never stops raining here in the PNW, so I'm paranoid I'll find out too late mine leaks. How do you want me to submit payment?
Is anyone having water in there driver floor board? Got in my 2022 today and the mat had a lot of water on it
@Alpoba My cab vents/tabs checked out fine, so I'm not going to do anything to them.
I forgot to post up a write-up on how to check the driver's side cab vent, since it is more involved. The passenger side only requires removing one push pin.
I say involved, but it only took me about a half hour to do this in the 100º+ heat.
Removing the seats is not required, thankfully! You just need to fold down the rear seatback portion. I used a box end wrench and pulled up on the pin to release the seatback. If you have the BuiltRight pull tab mod, this will be easier for you.
There are 7 fasteners that need removed (not counting the one push pin holding the fabric bulkhead panel in place). I circled the push pin in purple.
Removing the 7 fasteners allows you to remove the subwoofer and to move the amplifier out of the way. You only need to unplug the subwoofer (green connector) and do not need to unplug the amplifier from the harness. Remove the plastic push pin on the subwoofer that is holding the wire harness (outlined by the white rectangle).
There are two Torx T25 fasteners.
There are three 13mm hex fasteners.
There are two 10mm hex fasteners, one of which is a stud and is accessed after the subwoofer is removed from the truck.
After all this is done, you can move the amplifier a bit and slide the fabric panel out of the way enough to inspect the tabs on the cab vent. I used a flashlight and a mirror to easily check the tabs on the bottom side.
When you're done, and if you don't need to fix your cab vents, the fabric panel can slide back into place without much effort.
Bronco, thanks so much for doing this! your detailed instructions make it so much easier to grasp and prepare for what has to be done, every time!
Now if i go the distance and get to the vents, i’m 100% sealing them with silicone, even if they are intact😂
I installed the 3/4" Neoprene foam cord earlier today. It worked perfectly as I expected. Even had a nice sized thunderstorm right after I installed it. :D
@Alpoba
I’m done with the install. It turned out super easy with lifting the diamondback and just standing on AMP steps on both sides. Probably the first time those steps came in really handy for me. Maybe 2 minutes per side total time. Get the side steps😉
I did end up doing it slightly different from you. I left about 3-4” gap in the middle for water drain and better air circulation. Primarily for the reasons @Modman mentioned above. As you can see from the attached photo, even the slightest chances of water blowing/draining from the middle toward the vents would be close to nil.
Very happy this is done now. This vent flaw/issue has been bothering me long before i got my truck. It’s absurd that we even have to do this, but better be safe than flooded.
Good work! Now to tackle that underhood fuse box water issue next. (No issues with mine yet). That should be the last preventive thing left on my list.
Well I just put mine in the shop for a leak. Mine is not the same issue tho, I have the Ford rubber weather tech type mats and the water was in or on the mat, so it could not have come from that vent spot. I actually saw it dripping from the grab bar. Not heard back yet on what is what...but hoping its something simple like sunroof drain, but suspect its either the windshield or possibly a clearance light.
Ok, I got my truck back.....
Drivers side leak was some drain was kinked...assuming sunroof drain, but it was not clogged, it was actually kinked and had to be replaced. Glovebox leak was a seal on the firewall , think they just gooped it up and called it done.
Will see the next time it rains hard, I only noticed if it really rained good...its Texas so might have to wait to prove fixed...
Might be the AC leaking a fellow tremor owner from work has this issue too.
I had the same leak that dripped from the driver side grab handle. Inspected sunroof drain and it was not kinked or disconnected. It would drain properly to the inside of the fender. My sunroof seal was pretty dirty and the rubber looked a little dry though. I think if the seal isn't stopping enough water the drain gets overwhelmed and I was getting the drip out of the grab handle.
I cleaned the entire seal and sealing edges around and lubed it and haven't had a problem since.
