2021 F250 Audio Upgrade Suggestions
Your batteries are in parallel, route to the most convenient one with one caveat. The passenger side has terminals for both positive and negative hookups, but the driver's side may not have a stud for the positive wire. (The 22 did not have a stud) Look at the terminals to determine if there is a place to connect to studs, both positive and negative. Some people drill this out on the positive terminal and make a connection by installing a bolt to hook up devices they add. Once you look at it, you'll see what I'm talking about.
Never connect wires to the "tightening" connection, this will cause issues due to poor conductivity. The tightening screw has two pieces and different metals. These are not meant to carry current.
Thanks for the info.
Would you run positive and ground to the battery?
I know some people have just run there grounds to the point behind the seat.
I upgraded my body ground wire from body to battery to help with connectivity and just grounded amps against back wall ground points. There is another ground wire i think under the passenger side from cab to actual frame that i likely should have done as well but didn't. 8 months in without issue though.
I had aspirations to do the big 3 upgrade but with dual alternator and batteries, I haven't wrapped my head around how to do that correctly.
I would run both positive and negative to the battery in this setup if I deemed the current requirement high. I don't know all of the parameters for the equipment you have chosen but typically, a quality amp requires a good conductor to reduce any drop in the connections. The chassis itself is sufficient for grounding lower current but a pure copper conductor to the battery (with sufficient size) will usually be better than the chassis ground.
Here's why:
The chassis has smallish wire mesh that connects the aluminum to the actual chassis and from panel to panel under the truck. These "smallish" wires are not really designed to take heavy current and can actually burn up under extreme conditions. Direct connections to the chassis itself are sufficient for heavy current, but a copper conductor is better.
My general rule is that if the device draws more than 20A on a single connection, and I have to run more than 6 feet, use direct connections. Less than 20A, use the most convenient ground point. The typical gauge of wire in these cases is 12 gauge or smaller. Many times, when I run electrical, I use a twin type of wire like a marine style tinned wire. (Ancor) This also can be a noise reducer by not having multiple "paths" back to ground. Two wires fixed next to each other (or twisted) can reduce noise development where a chassis connection can route through different paths in the chassis itself. This isn't a problem for lights or air pumps, but "could be" for audio. It's also easier to run a jacketed 2-wire harness at the same time.
The length of the run will dictate the gauge of wire; most manufacturers will supply what they deem necessary for the connection but I'm a believer of overkill and run my own wires typically at least one size larger. The larger the gauge, the less drop you have in the wire. All wire will drop some voltage no matter what size; you are more interested in the best efficiency/cost parameters.
Hope this helps
Here's why:
Hope this helps
Thanks for the info. I am just going to run 0/1 from the battery to the back. That should leave me some room to expand the system in the future if I decide to.
