2021 7.3l Tremor: Do I need 2 batteries?
I would use cation with that. Yes you do have to get dual batteries to get the dual alternators in the gas but unless you are running a heavy gauge wire additional charge circuit directly from the batteries to your camper batteries/converter won’t be able to take advantage of extra alternator output. Also if doing that I recommend some type of ACR(automatic charge relay) or other type of disconnect to ensure camper load doesn’t draw down the truck batteries as well. Regardless of alternator options the charge circuit in the camper plug is limited to 30A so if using that there is really no advantage to the bigger alternator or extra battery for camper battery charging.
I’m aware of all those things. You’re preaching to the choir brother.
I was simply stating what other “applications” the dual battery option MIGHT be used for on the Gas truck.
If I was gonna boondock with a truck camper though I would immediately swap out the flooded cells anyway, and run my own dedicated home run from the batteries to the camper and use the appropriate gauge wire according to my intended use.
But I sure do have a lot of 4/0 laying around. Hahaha ?
Also good to know that when you have one battery that's going bad and has low voltage, it'll draw off the good battery and lower it as well (they'll both equalize to lowest common voltage). So the above post is correct. Go have them load tested. You may only have to replace one. In case you know which is the bad one, disconnect it until you can replace it. Usually, however, it's best to replace both at same time. For the reason I stated above.
Is this accurate? Most 2 battery systems have diode packs between the batteries to prevent one from taking the other down...especially on engines that don't require the CCA of both to start as in the 7.3.
It should provide redundancy...not that you don't have to replace a bad battery immediately...and as you said if there's age on them you might as well do both...but if one is bad I'd expect the other to maintain capacity.
If they don't work in this way for the gasser I think we've moved backwards in technology....
Just keep it as is.
If you were going to order one then you have the decision to make.
Congrats on the new Tremor I am sure you will enjoy your new 7.3 beast.
I have not looked at a dual battery setup in the 7.3 (or 6.7 for that matter) but my Dodge dual batteries are connected directly and what I stated is correct. At least for that vehicle.
Hi guys (and gals if you are reading)!
Two weeks ago, I bought a new 2021 7.3l XLT Tremor. I didn't order it. I didn't even know what Tremor was... I just wanted a new F250, and when I saw the Tremor package, I fell in love (I was gonna buy a F250, lift it, and put mud tires on it, so Tremor package was amazing). I searched local dealers until I found a Tremor in my price range, I drove 2 hours each way, and I bought it.
I love everything about the truck. It's fantastic in every way, in my opinion.
Today, I was watching an offroad video on YouTube and the guy said, "Every F250 Tremor comes with 2 batteries. "
I thought, "That's awesome. I didn't know I needed two batteries, but cool. I've got two batteries!"
Well, I just walked outside, and checked... My Tremor only has one battery.
Now, I'm wondering... Should I pay to get another battery installed?
I do not intend to run a winch, plow, additional lights, etc... I probably won't make many upgrades to my truck.
Do I want (need) a second battery? Thanks guys and gals!
If you’re not adding any accessories you’ll never need a second battery
I didn't add the second battery but probably should have for the price. The only things I plan on adding are some small lights to help hook up a trailer at night and I wanted to add an onboard air compressor. Will I have issues without the second battery?
You should be good. Just keep the truck running while you run the compressor if it’s for an extended time period.
No. You'll be just fine. The Dual Battery, HD Alt option simply offers the consumer the Factory Installed option if their up-fit requires it.
That's great to hear. And thanks for your input. Probably the only thing I felt should have just added cause of the cost but also didn't really think I needed it other than just a nice to have. Makes me even more ready for when it arrives here in the next week or so.
On the 7.3, you get a Single 397 Amp HD Alt with the Dual Battery option. Only the Diesel is available with Dual Alternators.
I have the 397 amp in the 7.3 and it is a dual alt setup and makes you take the 2 battery option. The 6.7 has an alt on each side of the engine where the 7.3 has them side by side on the drivers side.
The 7.3L is also available with the duals. The first 7.3L I drove did have the dual alternators. I opted not to go with it since driven from the main belt and batteries are hard linked together with no isolation. Currently with the amount of time use my 10K winch sees and the lower weights pulling probably not worth the cost to add a spare AGM combined cycle with ACR to operate the winch. If there is a 397A single alternator I do see that in my future mods list and would have sprung for that at order.
Yes, this is wrong. I stand corrected. Yes, Dual Batteries, Dual Alts.
Yes, my bad. You're right. Dual Batteries, Dual Alts.
Curious if anyone has looked into (or done) an aftermarket dual battery install with just the single factory alternator. If I'm not mistaken, the stock alternator in a single battery configuration still puts out like 240 amps. On the 7.3, rather than have the factory system with the batteries hard linked, I would rather have a dual battery controller/isolator that would allow you the extra capacity when needed but also protect you from doing something stupid and stranding yourself. I use a Blue Sea dual battery system in my Land Rover Defender and with the stock 90 amp alternator am able to maintain the two batteries under normal conditions or choose to link them when/if I'm winching.
This seems like a real easy mod. Just buy the ford second battery tray, a battery and the wiring needed to parallel the batteries. Instead of having the plus and minus going to one battery, you'd put the plus to one of them and the negative to the other one. But keep them in parallel. This makes them charge evenly. But without the winch it seems like overkill.
The batteries are hard connected no isolation. When one battery starts to fail years from now the you will hear it in how the truck turns over and you don't replace one battery at a time especially since the other won't be far behind it and you don't want to mess up your new battery.
The charging setup on these trucks has a computer that controls the charge of the trailer or camper that's hooked up. It will monitor your charge in your trailer batteries and top them up as needed so the positive wire in your 7 pin connector isn't always powered.
The alternators on these trucks are also not powered all the time they come on and off as needed. The truck uses a plastic ring to detect amperage coming out of your batteries on the 6.7 you can see it on the side of the passenger battery if I remember correct it's on the negative wire.
There is also a smart system in the BCM that is supposed to detect the truck batteries getting low on power like if there is a draw on the battery that kills it overnight. The bc is supposed to put the truck into a sleep mode where nothing will work until the key is inserted and truck turned on again to reset it. this si to help keep you from being stuck somewhere with a dead battery.
These computers are annoying when you don't know what they are doing or when I am sitting there trying to wire in a new 7 pin and I don't have power and can't figure it out BUT once you understand em and let them do their job I haven't had a truck that wouldn't start or a trailer that wasn't charged up ever so I guess there is that.
Not true. There is no single 397 amp alternator. You get 2.
