2021 7.3l Tremor: Do I need 2 batteries?
This seems like a real easy mod. Just buy the ford second battery tray, a battery and the wiring needed to parallel the batteries. Instead of having the plus and minus going to one battery, you'd put the plus to one of them and the negative to the other one. But keep them in parallel. This makes them charge evenly. But without the winch it seems like overkill.
Don't disagree with being overkill but was asking more as an alternate to adding a second alternator. In my case, this is way down the list of possible mods with items like on board air, BuiltRite racks and sumo springs draining the bank account first!
I got the duals, 7.3. Have the winch and camper. Probably will add lights eventually. When ordered I think is was like a $200 option, so why not I figured.
Yep. If I had ordered one, I would have done the same thing.
But, I just bought one off the lot. Oh well. I'm sure it'll be fine. I'll be happy with my one battery.
You will. A nice cost effective alternative I did on my explorer was to replace the original with a deep cycle AGM battery. It would power a fridge for 3 days and still start the car.
Damn! That's a good idea.
When my oem battery dies, maybe I'll buy a fancy battery to replace it.
Thanks!
I only have one battery, but am considering the second as I will be adding the winch soon. Don't really need it, but may do it anyway.
With respect, you guys do not need a second battery to run a winch or some extra lights. Sure, there are legit cases where a person needs a second battery, and one example is operating a snow plow + additional lights in a commercial application. If a person was plowing on an individual/limited basis, chances are extremely high one battery will suffice.
A second battery can be a great thing when it’s needed—but it can also be a PIA. From what I’ve read at places likes Facebook, it seems some guys are adding the second battery because it sounds tough and/or cool and it doesn’t cost much (relative to the cost of the truck, anyway). The need for the additional battery is simply not there in most cases I’ve read.
The above is my opinion, of course, but it’s an opinion formed by >25 yrs of doing this type of thing. I use a Warn winch extensively on my feed truck. My service truck is loaded with floods & spots so we can ‘shed light on the subject’ in the field at night, plus the welder and air compressor are hooked to the truck’s battery (for elec start). Neither of these trucks have (2) batteries.
I wish you all the best,
The only time you'd probably really need the second battery is if you could not run the engine and needed a lot of battery power. This might be if you got into water up to the hood, or the truck was on its side, and you had to winch yourself out without the engine running. Or if you were running power to your trailer overnight and didn't want to leave the engine running. But anytime you are running the winch, the truck should be running if possible, and a high idle would also be nice. Even when airing back up after coming out of the desert and filling eight tires, with your lights on and charging the trailer batteries with a 50 amp Anderson plug. The engine should be running. It's hard on starting batteries to be deeply discharged and will shorten their lives. Just be a little bit careful if you really use a lot of power, run the engine if you can and one battery will be fine.
With two batteries, when one starts to fail, you can notice it because of a slight difference in the cranking speed. I can always tell with my Cummins trucks when one is going bad. To find out which one simply pull the positive lead off one and see if it will start after sitting for a while. If it does, try the other battery. The bad one will have trouble starting the engine. The bad one likely has a short and will drain both batteries in a day or two, even if only one is bad. Every time that happens to me, I replace both of them. But you can disconnect the bad one and use the truck that way in good weather if needed.
Yup, I like the Optima Blue Top Marine batteries because they have an extra set of threaded connection points on them to add your accessories. ????
I ran a set of those in my Old 7.3 Powerstroke and got on average about 6-7 years out of a set.
Do both alternators charge at the same time, with the 397 option? Or is it only one at a time?
