B pillar label says 9/20Could everyone that has had the transmission issue share the build date of there truck? This would help to figure out if this is an issue with a batch of trucks or if its a bigger issue.
So far so good. I have put about 700 miles on it and no noise.It's the 27th now, what was the outcome??
9/20 for me as wellCould everyone that has had the transmission issue share the build date of there truck? This would help to figure out if this is an issue with a batch of trucks or if its a bigger issue.
Our build dates obviously way past the Jan/Feb dates on that recall notice someone posted9/20 for me as well
At least now, others will know about the issue, and know it's an easy fix. Mine seems to be running good now.Our build dates obviously way past the Jan/Feb dates on that recall notice someone postedMy bet is there will be more
Excellent nois... I mean news..So far so good. I have put about 700 miles on it and no noise.
HmmmBuild date 09/08/20.
Transmission has noise. Dealer states torque converter on backorder till next May. Ford authorized a replacement transmission that is also on backorder. Was told new modifications are being made for a 3rd gen
That blows...A 3rd gen tranny, already????Build date 09/08/20.
That is strange. I was able to get mine fixed and the torque converter shipped and received in less than a week. I dropped it on a Wednesday, called the dealer on Friday and they had already received the part. I have had no issues with the truck since the repair. I got the truck back on Oct 19. I don't know why there would be a 3rd gen, if the repair was a relatively easy fix.Build date 09/08/20.
IDK brother. That’s what is being told to me by my dealer. This is coming from our regional manager from FORD. Again we were told that the converter is on back order until May 2021. Ford approved a new transmission which I prefer anyway. That is on back order as well. I was told to drive the truck as is until replacement transmission is delivered. I guess a lot can happen in the couple of weeks since yours was repaired.That is strange. I was able to get mine fixed and the torque converter shipped and received in less than a week. I dropped it on a Wednesday, called the dealer on Friday and they had already received the part. I have had no issues with the truck since the repair. I got the truck back on Oct 19. I don't know why there would be a 3rd gen, if the repair was a relatively easy fix.
I was hoping that my transmission would be a full replacement too, but who knows. Everything seems good on the truck. I have the warranty, so at least if it craps the bed, I can still get fixed.IDK brother. That’s what is being told to me by my dealer. This is coming from our regional manager from FORD. Again we were told that the converter is on back order until May 2021. Ford approved a new transmission which I prefer anyway. That is on back order as well. I was told to drive the truck as is until replacement transmission is delivered. I guess a lot can happen in the couple of weeks since yours was repaired.
My 3.5 Eco 2018 F-150 that had the (smaller) variant of the 10speed. Great truck power handling etc! However, from early on - but very intermittently there was an issue - at first it sounded like a preignition misfire but then mostly mimicked loose fluttering heat shielding in the exhaust system (the later may be a sound only those who live in heavy road salt areas know ?). Later it was occurring 1800-2100 rpm regardless of gear or speed and it never threw a code. Every time I went to dealership (with ever more detail and even recorded audio) - they found nothing or said they flashed the ECM. Finally it was happening more regularly (6th -10th time driving) and including a muffled thud that ended the flutterring noise. I’m virtually certain it was a torque converter lock up issue of some type.Thanks for the input. I was thinking it would be different than my F150, but it just didn't feel right. I wonder if this is a similar issue, just didn't cause the leak. Sounds like something is scraping. Dealership said everything else in the transmission looked good. No metal shavings and fluid was good. Keeping my fingers crossed. I was hoping they might just replace the entire unit, but guess not. I will definitely keep everyone appraised of the situation.
I’m an aviation tech and I know how hard it can be to troubleshoot and isolate very intermittent “ghosts in the machine” especially electron gremlins. We have to dig until we get answer(s) but I suspect dealerships have a different matrix. I traded that truck in because at some point the problem they were avoiding would be mine alone. I also strongly suspect the problem was not just my truck. May have just been a crappy dealership but it is a larger one????
Well, I'm not giving up and have no plans to get rid of my truck. My dealer isn't taking it too seriously I don't think but I will keep exerting pressure. I even asked if they had some other Super Dutys on the lot and they do, and we will be cranking some of those up to see if the noise is there, with the same 10 speed transmission of course. If my dealer can't do anything further then I'll go direct to the Ford site for support, and keep on and on and on...
