Must of missed all the blown motors on the 7.3 lolNot starting a gas vs diesel pee contest here, and I am a diesel guy at heart, but yet another reason I went with Godzilla this time around.
OP, sorry to hear this. Hope it works out for you.
Nooooo, couldn't be?Must of missed all the blown motors on the 7.3 lol
I have no idea if they would cover the repair with a DPK installed; but let’s just assume they would cover it, Ford warranty repair procedure for failed CP4 - I believe - is replace everything. So not likely they would save part of the cost. If not covered under warranty, the owner would certainly save the cost - if they trusted that the DPK worked as advertised.With the DPK they would only be replacing the cp4, nothing behind it. Quater the cost, less down time for parts. And they have to prove the DPK caused it. More times than not a failed cp4 is not covered under warranty, even on totally stock truck.
That's because that occurs only on extremely, extremely rare occasions.Must of missed all the blown motors on the 7.3 lol
So do you suggest using a fuel treatment every fill up? Any other suggestions would be appreciated too.I’m in the Diesel parts world and here’s an outline on why CP4 pumps are prone to failure. My experience has seen failures from both lack of lubricity and dry starts when fuel filters are changed. (Not primed correctly). I will tell you that I’ve seen 400k miles on CP4s without issue and 60K premature failures, so it’s somewhat a mystery but definitely issues exist.
There are many theories as to why the CP4 pumps fail, but it is typically associated with a lack of lubricity. This ultimately ends with metal shavings being released into the fuel system. One potential contributing factor is the ultra-low sulfur diesel (USLD) fuel available at the pump nowadays. It is better for the environment, but unfortunately offers less lubricity than its predecessor. Since the CP4 uses fuel as a lubricant, the lack of adequate lubrication can increase the amount of friction on the internal metal parts such as the drive cam and roller lifters. As a result, small metal particles or shavings begin to get distributed throughout the fuel system and can end in catastrophic failure.
The formation of air bubbles inside the housing can also occur if the pump struggles to supply adequate fuel. Air in the pump means that metal is rubbing directly against metal or possibly allowing a lifter to rotate. Since there is no mechanical lock or keyway keeping it properly oriented a lifter can spin 90 degrees. If a lifter has turned sideways it will begin to cut into the main shaft, rather than ride on it smoothly. All these potential issues will result in accelerated wear and metal particles in your fuel system.
I do not believe using it that frequently. I do suggest always filling tank from a high volume station every time to avoid any lubricity issues and 1 a month fuel treatment if you want additional peace of mind. Just my opinion and what I do in mine. ThxSo do you suggest using a fuel treatment every fill up? Any other suggestions would be appreciated too.
I feel for you my friend. Hope Ford takes care of you.The CP4 got my truck on the way home from Boy Scout summer camp. 61,600 miles, fuel filters changed every oil change.
JA345 how did you go about getting in contact with Ford corporate. I had to leave me truck in Texarkana and they are telling me the parts or backordered
Or once they fix it add the DPK, the new CP4 may never go out, but if it does it will not damage everything else.yes they are covering it under the warranty. Plan is to run the truck until the motor warranty is out and ditch the CP4 for the DCR conversion pump.
What I am saying is add the DPK after your warranty repair as the new CP4 may never fail, but if it does the DPK will save your fuel system, then replace with the DCR. If you install a DCR the DPK can be removed.I read that the DCR pump will not work with the DPK. I had planned to add the DPK once the warranty is done.
DPK parts and labor approximately $1100What I am saying is add the DPK after your warranty repair as the new CP4 may never fail, but if it does the DPK will save your fuel system, then replace with the DCR. If you install a DCR the DPK can be removed.
The DCR is basically $2000, labor to install will vary but I will guess $1200 to $1500.
Call ford customer service. They were excellent and responsive through the whole process.I have been reading the last couple of hours, probably going to go the DPK route like you mentioned
Clarification, you would only REPLACE with the DCR if by freak chance you had a 2nd CP4 failure. But the DPK would save your fuel system. I personally made the decision to add the DPK now, only 35K miles as I want to avoid breaking down away from home. Now the DPK will NOT prevent CP4 failure, but most likely will allow you to limp home. What kills the motor in most CP4 failure is the shrapnel reaching the injectors, fuel rails etc. The DPK prevents that. I will gamble on warranty coverage with installation of my DPK for several reasons, but the main two are failure away from home, and the timely process for parts to be ordered. Time is money as we all know. Fact is, if I happen to have a CP4 failure, I will not go to the dealer, I will have the DCR installed, and be done with it.What I am saying is add the DPK after your warranty repair as the new CP4 may never fail, but if it does the DPK will save your fuel system, then replace with the DCR. If you install a DCR the DPK can be removed.
