2020 6.7 Fuel Pump
One thing I heard in this thread and I totally agree, Good Fuel Is the answer. Nothing ruins a fuel pump quicker than poor fuel and especially water. Change your filters regularly and use a Good High quality Fuel Additive. With over 20 years experience with BG products , personally and retail, i have seen great results. My 6.4 went 189k with no fuel or CEL issues with use of their additives in every tank. A one gallon jug would take me 30k miles. Go to bgprod.com to see all of heir products.
Its all about the FUEL.
Can you convert back to a CP3 like people are doing with other brands? My buddy's Duramax has a CP3 conversion and it was the best thing he's done.
I used to work for Bosch in the 80's. The Germans don't like things that fail, they over engineer their stuff. Bosch basically designed diesel fuel injection, so diesel is really their foundational bread and butter. As an example, they made injectors for John Deere and Deere wanted them to make cheeper injectors that didnt last as long, so they could get more service calls. Bosch refused and Deere went with another brand injector. So, if some component of their design is failing, I think you can be pretty sure they aren't sitting on their hands about it. Now it has been 30 years since I worked for them, and that might have changed, but I doubt it.
My truck has 6700miles the check engine light has come on 8x since 500 miles. Dealer at 3000miles even blamed me for having bio diesel in it and wanted to void my warranty. Now after 6 visits and a complete fuel system flush, they said I have shaving in the fuel system. I have a lawyer already starting the lemon law prices. I love the truck but very frustrated at what’s going on.
For under the hood HPFP it's not a "new" issue, but one related to people not using quality fuel and an fuel additive.
For the LP fuel pump newer in-tank fuel pumps haven't really been modded by the aftermarket just yet.
Who has the best quality diesel fuel?
You have every right to be pissed. Hope they take your truck and give you a new one identical and keep the loan balance identical if there is a loan
I have a 2020 with a 6.7. Upper plastic filter sprung a bad leak on the freeway, due to lack of fuel flow to lift pump the Aluminum pump ate itself but ford wont warranty it. 15 k on truck.. Anybody else experience ford bs warranty? There is a Recall on 2021 filters with the same part #.
So there is a long article on the CP4 in a diesel magazine that's out this month. I dont have the publication handy but will be home on Sat and post the source. The CP4 sees the most failures in the Chevy trucks. Fords, not so much. Oddly enough, they said AIR in the fuel line was the most likely issue. While fuel and general maintenance is important, they did said air was the #1 that caused the CP4 to fail.
Not agreeing or disagreeing with article. Just passing along that info.
Here's another article that mentions it.
"The formation of air bubbles inside the housing can also occur if the pump struggles to supply adequate fuel. Air in the pump means that metal is rubbing directly against metal or possibly allowing a lifter to rotate. Since there is no mechanical lock or keyway keeping it properly oriented a lifter can spin 90 degrees. If a lifter has turned sideways it will begin to cut into the main shaft, rather than ride on it smoothly. All these potential issues will result in accelerated wear and metal particles in your fuel system."
Had a FASS fuel filter and disaster kit installed with a larger fuel tank. Just trying not to be stranded in the middle of nowhere with a trailer in tow up in the mountains. If the pump goes maybe I can get it fixed relatively quicker. But the FASS is supposed to reduce a lot of air so hopelfully get 100k out of the cp4?
2020 Fuel pumps are different......apples and oranges.....until we know more of course.
Run a fuel additive....it's easier till we have the correct information about the 2020 HPFP which is a different design.
What additive are you running with your diesel?
Bad places for fuel can be quite a discussion. Some people will only use high traffic pump locations due to the turn over in fuel thru the tanks. Other people will only use reputable stations.
Bad place can also be your best friend's brother's uncle who has a 1,000 gallon transfer tank beside the barn....Help yourself....UMmmmmm.....no I'll pass thank you very much.
Fuel additive discussions are fixed to the ULSD not having the lubricity properties that people claim to be part of the older style HPFP issues. I haven't learned of the specifics of the newer 2020 HPFP so I'd have to stick to using a fuel additive till more info comes out to digest.
I can only share what I have been running with good results. Howe's Diesel Treat that I can find at WalMart pretty cheap. For an extra boost they have an injector variant as well. I splash the Diesel Treat at every fill up, while I use the injector variant once/twice a month.
So I looked up Howie's diesel treat. Talks about preventing gelling. I live in Vegas and it is very hot and doesn't get very cold. Would this still be a good additive? Thanks
I have been using Archoil fuel treatment in every tank of my 2020 for 2 1/2 years. It is available on Amazon.
Howe's has a two versions that I have been using both are giving me good results.
This version I had been using for only a short time...so far so good.
Forced???? LMAO
FCA US, LLC will conduct a voluntary safety recall to replace the HPFP, update the Powertrain Control Module (PCM) software, and inspect and, if necessary, replace additional fuel system components free of charge.
