2 cooling systems on 6.7?
AZsurveyor
Tremor Maniac
Founding Member 📜
Meetup Organizer 🌵
Phoenix, Arizona
2022 F350 KR TREMOR RAPID RED 6.7L
2007 F350 KR CC 4x4 LB
I never have and I never will claim to know everything about anything, much less the 6.7 but we have two seperate cooling systems? I was today years old when I found out.
What else do I not know that I need to know?
What else am I missing that I should know?
i've always wondered why Ford would run the compressed air from the turbo through an air-to-coolant cooler that used coolant from the engine. Makes more sense knowing that cooling system is not tied to the engine coolant.
EDIT: my curiousity was based on the assumption that the temperature delta wouldnt be enough to justify such a large contraption... however, under serious boost, it likely would be.
This is more than I can mathematically understand but was shocked to know how intricate the system is and it only became more interesting with the introduction of the water cooled turbo in the HO.
I was hoping our engine experts would have chimed in more to discuss this in greater lengths.
Ford been running two systems for a while now.
Didn’t Ford start that with the 6.4? I may be way off base here but as soon as I started reading this thread memories of 2 cooling systems in regards to the ‘08 6.4 I had eons ago sprung to mind that I don’t even remember having before now
Damn! That guy must have kept driving a while with the CEL on.
The secondary system is a pain in the ass to get all the coolant out of. It's also very hard to get the air out of if you don't use a vacuum.
Getting all the coolant out isn't a big deal if you are on top of maintenance. Drain what you can and fill er up. The air is a big deal. Think water hammer in plumbing pipes. Except its hammering away at your heat exchangers and radiator tubes. It can also cause hot spots.
I don't consider myself a 6.7L expert, but as a user I ask the same questions, or try to find the answers so I can share the info.
I'm not even sure what we are trying to answer. Now to give some info that I can.
1) There is a secondary coolant temp sensor, Ford just doesn't apply that data where you can see it. My CTS3 used to show it on my 2015, not sure why my 2022 can't show it other than Edge hasn't updated the PID list.
2) The CAC and secondary cooling system have a bigger job. My thoughts are it's simply to give a intake air temperature that's sustained. Meaning even when extremely cold or extremely hot outside, the IAT will always have a sustained level. Pushing high boost....yea she's going to get hot, but that's what the coolant is for.
3) If you look over the Coffee Table books that show the coolant flow path....the secondary system is ALL about the CAC. (no pun intended) There is a small coolant feed for the fuel cooler.
4) If you want to lower the EGTs, it seems as a larger (more flow) CAC would be a good idea. How much can be argued.
5)
So....what's your questions? 😎 😎 🇺🇲 🇺🇲 🇺🇲 🇺🇲
For my 2022 the coolant intervals : Normal Ops is 200K miles, any Special Operating Conditions is 60K miles.
Given those considerations I'd say 30K miles isn't too early, but might be quite a bit sooner than most really need.
No particular question since I don't know anything about it other than it cools the engine through a secondary source.
Thanks for dropping some jewels of knowledge.
I think I saw a Youtube AROD video of him suggesting a 30k mile drain and fill for both the primary and secondary. Isn't that kinda early?
I would say it is. Maybe it was the old orange coolant?
