7,500.When did you guys change your oil for the first time? I heard something about doing the first one sooner then you usually would?
Thanks
10w30 & 5w40.Thanks for the write up. I’m a first time 6.7 owner and I noticed the cap has 2 oil types on it. What would be best? (I’m sure I could google this but it’s more fun here to learn)
If you don’t tow, or tow lightly (under 5000), the 10w30 will serve you well. Even heavier towing for short distances. Like a trailer you only use for the dump and mulch runs. If you tow heavier, go 5w40. Unless you never see below freezing. Then I’d recommend 15w40 because the cold start need for 5w isn’t a thing.Thanks for the write up. I’m a first time 6.7 owner and I noticed the cap has 2 oil types on it. What would be best? (I’m sure I could google this but it’s more fun here to learn)
