Seems to work somewhat better on the repositioned MY23+. Mine will start charging consistently when I hold it in place.
I’ve got a 13 Mini though, so as soon as I let it go, it slides down and no longer charges as it loses alignment with the induction pad. I’ll have to get a 3D printed spacer for the bottom if I want to use it. It seems to work fine on the wife’s regular sized iPhone. I moved my MagSafe charger from my Challenger to the truck due to this.
I wonder if there was any changes to the pad between 22->23+? Is it something that can be swapped to test?
Wireless charging usually depends on position//stability, and case thickness. It seems like the Ford charger only has one induction coil in the middle from my test with my smaller phone, so depending on where it is on your phone, it might be a matter of putting the phone down in a different position (upside down For example) so that more of the coil comes in contact. This plays into the stability comment…if the phone is shifting, and the coil is not in good “contact” it’ll stop charging too (this is part of the reason MagSafe on Apple uses alignment magnets, and why Qi2 chargers are integrating them too). Case thickness is another. Really good QI wireless chargers are supposed to be good for up to 1.6”, but in reality, I don’t think I’ve ever seen one that works with much past a thick phone case. These Ford chargers already have a thick rubber mat above the plastic that houses the coil, so that puts the deck stacked against someone using a thick case like an Otterbox if the alignment isn’t steady and “perfect”.
If you’ve tried positioning it repeatedly, and without a case to test “perfect” conditions, it might be defective, but as Blade mentioned above, it’s possible it’s just a piss-poor design as the ones in the Bronco without the rubber bumps works fine.
