Winter traction devices aka tire chains
A lot of people commenting here with far more experience than I have. That being said, when I've had to chain up, I chain all 4 tires. It's adds a few extra minutes and frankly, the cost of the chain's and time pale in comparison to what I've paid for the truck.
I hate waiting for a tow or dealing with insurance companies.
I’m also in the camp of being prepared to attempt to get out your self out rather than having to wait for help if possible. In the past found out some areas tow trucks won’t leave a maintained county road and no recovery from BLM/Forest Service roads. Now I carry chains and lots of recovery gear.
Honestly running highways without a heavy load have not run across many situations where would need chains with the 3PMS Duratracs. The tires actually have preformed quite well in those situations.
Now the side streets and trails are a different story. With rain right before the deep freeze and record December snow fall has made it much more difficult to get around in my area. It can be as simple as getting off the cleared road on a incline a little bit and bingo instant stuck if not running studs or chains.
I bought the square link chains from TireChain.com for Load Range E and they are way too big on the stock Tremor Duratracs. The tails are on the tightest links and the cams tightened by hand (no tool needed since they're so loose).
I sent them a request to exchange so fingers crossed they're easy to work with.
Update on this. TireChain.com hasn't returned my email (it's been 1-1/2 days), so I called today and they knew exactly what I was talking about. Load range E tires run smaller for chains (maybe because the chains fall between the lugs?) so one cross chain needs to be removed from the non-hook side.
  • Useful
Reactions: ccw
Appreciate the update. Might have to do that with my chains as well.
I don't love how there's a gap with the farther span, but I suppose it doesn't hurt anything?
Aside from that, everything clears. I'm ordering a second set for the truck (so I have enough for all 4 tires) and a set of the same for the trailer. When I talked to TireChains.com on the phone, they said I need either these square links or heavy duty twisted links for my 17,000lb trailer. They said cable or diamond won't work. The twisted links would provide more clearance (which I don't need) but won't last quite as long (which probably isn't an issue for me either).
Looks good but I wouldn't trust the zip tie. If it breaks while you're driving that loose end of chain can tears some stuff up, like your rim or a fender. I would consider shortening the chain since you won't need those links anymore.
Good point! I will do that.
Edit - I'm going to leave a couple of links because they are needed to get the chains on before tightening. But those shouldn't cause much damage.
Just make sure all of your cams are unlocked to give you maximum length. Keep the tails short as possible.
As someone who has for 35 years crossed Donner Summit hundreds of times during the snow, I can tell you this. If you have four wheel drive, chains are not required. If the conditions where to get to the point that it was so bad a 4 wheel drive would need chains, they would just shut the road down. Yes, during chain control, you go through a checkpoint but they just verify that you're in four-wheel drive. No chains required. Most of the time if you're in a 4 wheel drive, they just wave you through. The part about having to have chains in your possession is in relation to big rigs. During the months from, I believe, November to May, big rigs are supposed to have chains in their possession whether or not chain control is in effect. They do inspect those vehicles for chain possession in situations where they may be going to chain control shortly. I have crossed in regular cars, four-wheel drive trucks, and big rig tractor trailers. Not going to lie, it sucks chaining a big rig. Glad those days are over.
Good luck and safe travels.
This is the most correct response. As someone who lives up here, and chain control is 3/4 mile from my house, I keep chains in the truck just in case, but in all my years I have never been asked to see them and I have never used them. I have been stopped and asked if I am in 4wd and they take a smart look at the tires, but never asked to see my chains. I have been asked a couple of times if I had chains, but not asked to show them.
A funny thing, if it isn't too bad and the snow isn't blowing a lot of the times they just wave you through but the worse the conditions the more they pay attention. I would think it'd be the other way around so they could get out of the weather!
Saw a picture of snow chains this morning on the site….
And living in wa state I’ll prob need a pair eventually… since this post has been over a year now, was wondering how everyone’s chains did over the years?
I've only put my chains on twice..... when the snow got really, really deep and I started spinning and barely able to get around. I live in a neighborhood with very steep and narrow roads and it's not uncommon to get 2 feet or more in 24 hours. Most of the time, studded tires + 1500# of weight in the back allows me to get around just fine. With the chains on, I feel like an unstoppable bulldozer. It just keeps digging and pushing. But when I get out to the plowed-ish road, I can't go over 25 MPH and that really sucks. The chains will continue to stay in back of my truck and used only when necessary.
Looking for what everyone got for the stock tires …
Replace the cross chain you removed but just before the connection. Bingo. That's what I would do, but since the Owner's Manual strongly suggests NO CHAINS on the LT285/75-18 (for several reasons), I am going to get a set of cable chains strictly for icey situations. Really don't need chains for much else w/ the Duratrac tire and the Super Duty Tremor's 4WD.
Read your manual? Not everyone's got chains for the stock Tremor tire.
Now, if you have a standard Super Duty, then, have at it. Just use your truck's tire size to order a set of good-quality tire chains. Cheers.
I just run studded tires during the winter here. Just looks like so much stuff up front that a chain could take out.
I have the aggressive v bar chains from tirechains.com for all four wheels. Never had an issue with the chains taking anything out while hunting. Keep your speeds reasonable, make sure they are tight and do something to control the tag ends and you are good. I found that laying the chains over a 4x4 in between the crosslinks and then driving up on to that 4x4 really gave me the ability to get them a link or two tighter before tightening the cams rather than draping them over the top. Now in the winter I keep a couple of 3ft sections of 4x4 in the bed
