Winter killing batteries
What's everybody's measuring for open voltage on their AGM? Just got the replacement from the Advance Auto and it measured 12.5V at the store. Installed in the truck and I'm getting 12.15V. I also measure 5.7A draw but will go back out in a lil while to see if that drops.
33f outside right now
To get an accurate reading of 12V sealed battery health (as in, unable to use a hydrometer to measure specific gravity in each 2V cell), the battery should "rest" for 8 hours or, overnight.
Trouble is, there seem to be many small demands made of our trucks' batteries these days so they never really get a change to rest. It's not so much that they "need" rest, but rest is needed if we are to accurately measure it's voltage.
Point being: 12.5V is par for a battery in a parked truck after it has seen regular use.
But after sitting for a few days in near-freezing ambient temps, 12.1 is on par, whereas if 12.1V were to have been measured on a 70* morning after sitting all night with no electrical demands, 12.1V would be nearly a dead battery.
There are temperature charts for battery State of Charge/SoC charge voltage percentages. You may find them online. There are many, and there should be differences between standard lead acid batteries and then AGM lead acid batteries. Good AGMs are full at 12.8V, and good "regular" starting batteries are full at 12.6V.
/random info
From the inaccurate dash readings I have 13.5v to 14v and it doesn't seem to matter how long its sat. I don't go past 3 days parked usually.
From the maintenance done on Dec 4th they said one battery was at 731 CCA and the other was at 681 CCA... I thought that would be closer together than that but I'm assuming one battery takes more load than the other initially.
Doubt this info counts for anything here haha but thought I'd share regardless 😉
Lots of good ideas and experience here, but I think your battery may be toast. You'll need a load test to be sure...getting to that.
Voltage is one indicator of car battery health, but not a complete one. Think of it like looking over the side of your boat. You can tell if you're in the water, but you have no idea how deep it is.
You can prove this to yourself by putting two 9-volt transistor batteries in series. Put a meter on that and you'll get 18 volts. Should have no problem starting your truck, right? Good luck with that.
As many have already said, batteries ain't what they used to be. Like everything else, the quality has gone down and the price is way up. I just paid over $400 for a Group 34 Odyssey battery for a piece of equipment I own. (WTF is that!!)
What happens a lot of times is that the anode and cathode plates inside the batteries warp. When they do they touch in places and form an intermittent short. It will work fine for a while, but then will leave you stranded when you least expect it. Blame this on greedy corporations, Chinese imports, climate change, or whatever you choose but it is much more frequent than in days past.
I got sick and tired of taking batteries to the local store where every battery they tested was bad and I needed to buy a new one - from them. I did what little research I could and bought this battery tester.
Foxwell BT705
There are several out there, and I would recommend to anyone with multiple vehicles to purchase one. The one I listed seems to be reliable and has given me valid readings on known good and bad batteries. I would say to get this, or something similar, and load test your own batteries. One or two tests and it will pay for itself.
I see your truck is a 22 As is mine. My batteris just went out recently as such I bought two AGMs and stuck them in there LL $350 dollars worth ha It had been quite cold here and my truck had sat more recently. MInd you today was in the 50s with lows at 40 and it will be for the next 4 days.
FWIW Mine son and I both have ‘21s Winter temps in teens and below 0 in winter, summer towing in 100+ temps not uncommon. As said before heat extremes kill stock batteries. Both of ours went out with-in 2 months of each other when temps dropped below freezing this year. We do have diesels though so X2…
Quality, AGM as others have said. What is the stock warranty? 3 years…hmmmm…annoying!
As many have already pointed out, batteries are not a guaranteed at 12.5 or anything else. The voltage can vary from one to another due to chemical composition, time charged, temperature, remaining capacity, etc.
The trucks alternator is NOT a charger. It will recharge the battery after running a while but may also not fully charge it for the load demand from it versus the time it is allowed to run. So, the resting voltage could in fact read low after running. A battery at 11.5 volts is considered dead. A battery lower than this is usually an indicator it is beyond recovery to full capacity.
The Foxwell mentioned by @15w 40 is an ideal way to test the battery for capacity "potential", but some considerations must be met. The battery should be disconnected from any load. (Avoid using the "in vehicle" mode on the Foxwell, very inconsistent especially with two batteries in parallel.) Allow to rest for an hour and make the test. It is critical to have a very good connection on the battery post with the analyzer as any resistance in the connection can give you a varying result. A low battery does not mean it's bad, it means it wasn't charged properly. The Foxwell will determine this. Even if it gets a "bad" reading, charge it overnight with an appropriate charger, allow it to rest, and test it again. You will likely get a different reading.
The Noco maintainer can charge the battery completely over time. The issue comes as while it is charging, and the truck comes on, the current draw of the truck can equal the charge current out of the maintainer, rendering a 0-delta charge. (Not enough current to keep the battery at full voltage while any accessories are activated.) I found that the 2A charger/maintainer was not enough to keep the batteries charged and still have all of the truck peripherals still operate and recover the battery capacity. Use at least a 5A maintainer and even consider a 10A for two batteries in parallel in cold conditions.
It's been said by numerous references above, the heat of summer kills your batteries, you find out in the winter.
An AGM fully charged with no load will likely read around 12.8V when new. This will go down as it ages. 12.5 is a good reading, in many cases, for a year or more older battery or one that has not been recently "fully" charged. As a lead acid cell is 2.1V (X6), ideally the battery should sit at 12.6V when charged and resting. AGMs seem to hold this a little higher at 12.8, again, when new. This will drop quickly once a load is applied.
Also consider the accuracy of the voltmeter used and the lead connection to the battery. Especially when using an analyzer such as the Foxwell. (Any corrosion or oxidation may reduce the meter contact. Though somewhat insignificant when measuring voltage, it has more effect when the Foxwell is making its "capacity" measurements.)
And one more thing, the LED fans do in fact come on whenever you open a door, walk up to it, or other possibilities depending on how the control has been set up. There are numerous electronics on time schedules that come on and go off at varying times when you first "activate" the truck. Test the battery out of the truck (disconnected) to be sure, before replacing it.
Hope this helps
Hope this helps
I was keeping my response brief, while Canyon Trekker expanded on it - no doubt because he knows more that I do, but all his points are spot on and should be heeded for any load tester.
In my experience with the Foxwell, allowing the battery to rest before testing is useful. Also, if you got a "battery bad" reading try trickle charging it, let it rest, and try again. This can save you some dough in that a discharged battery can show up as bad and when properly charged actually be good. This could be a clue that something else is wrong with the vehicle charging system and not just a bad battery.
Most importantly, at least for the Foxwell, disregard and never use the "in vehicle" testing protocol. I have found wildly different readings testing the same battery in and out of the vehicle.
If you have a questionable battery you don't actually need for it to be "out of vehicle". Just disconnect the terminals and let it rest for a bit before testing. Anyone reading this post is capable of that or you wouldn't be on this forum to begin with.
You make very good points, covered it nicely. Glad to see your inputs here. I too use a Foxwell, it's the BT780. I've been caught off guard using the in-vehicle mode before, as well as the connection issues, that's why I mentioned it. 👍
Just to follow up on this I got a replacement from Advance Auto under warranty no questions asked. The battery measures a bit higher at 12.5V but the Schumaker load tester shows both new and old batteries dropped a good couple of volts under load.
Been using a BM2 Bluetooth voltmeter to keep tabs on it and started trying out couple of solar chargers since I park it too far from the house ie from an outlet.
I have thought about a solar charger. I drove 8 hours over the two days off and my battery showed (today) that it had 52% charge (12.5 volts). I ran the charger till it showed full charge. There is just too much stuff that runs when the truck is off. Very poor planning (unless you sell batteries).
I am tempted to install a battery disconnect switch.
'21 7.3 replaced OEM bats last weekend..no warning lights, nothing...struggle to start and then DB lit up like a Christmas tree went straight to the parts store..
Primary had so much corrosion on it it popped the positive terminal cover off...lol
