Whose Running MTs as daily?
Load index 128 is more than sufficient. I'd be looking for a new shop if they gave me a hard time about 128s on a 1 ton, let alone a 3/4 ton.
I run 127s on my F-350 which are also plenty.
I agree completely. Discount Tire however, does not. Doesn't matter, 4WP has people with a half a brain that know the vast majority of Super Duties don't have OEM tires that are 129 indexed - just the Tremors. 37s on order through them.
What in your opinion, respectfully, should the weight rating be? Honest question. Cheers.
Indeed. For example, my 2025 F350 Tremor has a RAWR of 7050 lbs.
Considering the tire requirement of that rear axle by itself, we total the load capacity of both tires. 3968 X 2 = 7936 lbs, and that is if my truck's rear axle has a heavy cargo load/trailer tongue weight on top of it. (Edit: Is there a dynamic load factor of 125% that should be considered in there somewhere? The RAWR?)
I think you misunderstood me - I think that any rating that clears 3,640 lbs of pressure @ 80 PSI should do for a 3/4 ton truck - that is a 125 load index. Vast majority of 37x12.5x20 are 126 load indexed - which seems fine to me, and matches what Ford would put on a Super Duty that came with the OEM Bridgestones. Discount Tire's employees just read the sticker inside the door that says 129 and won't install the tire if it is less, unless you go to 12 ply (selection sucks on F loads).
Thanks. I may have, but please know that my reply was not meant in a confrontational way. It was simply a question. You've answered it. Thanks again. Cheers!
Didn't take it that way. I just realized some people might be confusing me for the nervous nellie that won't do anything different than the sticker in the door. :)
10-4.
Kinda figured that, but if there's something to be learned about Load Rating I've always got an ear.
Ive run Toyo MT's on mine since new and have had zero issues in the rain, snow, dry pavement, mud, gravel etc. They perform amazingly and look even better. With that said, if most of my driving was pavement only id run the Toyo ATIII's. I have had excellent luck with those as well.
Completely agree with you except for the 80 psi part. Tires like the MT Legend EXP (which I run) achieve 126 load index at 65 psi, which also helps soften the ride while meeting RAWR spec.
I have no interest in running at 80 PSI myself. Just using that as a standard for gauging load rating. BTW: I really like the Legend EXP and MTZ - underrated tire. Let me know how they are working for you.
So far I'm happy with them. I like how they are softer and lighter than E-rated tires. They have been fantastic for 8500 miles of towing. They are rock solid stable in heavy rain. They did great during the Sedona trail run with zero chunking and looked good as new after being washed. I don't need great snow performance in Arizona. I would like them to be a little quieter but have read mixed reviews whether the Toyos or Falkens are any quieter.
If I may offer, I ran BFG MT on my GMC for 34 years. They would spin in the rain if the go pedal was pressed a little too hard, but I always put another set on when one wore out. I liked the look and the fact I could go where I wanted to.
