Wheel Well Liner Price
Big_Ed
Tremoraholic
Louisville
USAR Retired/Disabled
N/A
Ok, I just realized that if you order a truck that comes standard with rear wheel well liners, like my KR Tremor does, and you choose the option for front and rear, they charge you for both the front and the rear, eventhough the rear come standard.
I built out a F350 KR Dually, where the only option is to add front wheel well liners, and the option is only 180. So when you add them to a truck that comes standard with them on the rear, they charge you a total of 325 dollars for the rear and front, instead of 180 for adding the front.
Ford doesn't offer the option to install Dually's with rear Wheel Well Liners. You can install them, they'll fit. Just not from ford. Don't know why ..??
There's funky stuff going on the website with the wheel well liners. If you order the Black Appearance Package on the Lariat (which comes with the rear wheel well liners) - you can't add the fronts, it will automatically remove the Black-Out package. How does that make sense?
In that case it's just a dumb programming thing with their SKUs - the black appearance package has the option called something like "rear wheel well liners only" so you can't add the front liners without removing that option. Same reason you can't add both the diesel and gas to the same truck - they exclude each other.
The reason is that the Black Appearance Package comes with front wheel well liners, though apparently they’re more of a carpeted surface rather than hard plastic (has some fuzz to it).
Some folks have been able to install the plastic liners over them, but that’s why you can’t order the front wheel well liners with the Black Appearance Package.
Oh interesting. I assumed that fuzzy front liner was the standard on all super duties and the front wheel well liner was the plastic going over it.
So if you don't go black appearance package and you don't get a front liner, what's there?
Does the Lariat Ultimate Package Tremor come with rear wheel liners?
