B
BlueKilla
Guest
Probably a good idea then to check the banjo bolt when rotating the tires or doing an oil change to make sure ours are all snug - probably a freak accident or faulty bolt/missing washer. Thanks for providing the TSB on the transmission.
Edit* forgot to mention, check the inside of your rim for paint bubbling/damage and make the dealer replace it under warranty. Brake fluid does a number on coatings!
