UPDATE: TRANSFER FLOW REPLACEMENT TANK FOR GAS SUPER DUTY'S
Still just interested in the TransferFlow solution. We know they're making it, COVID hysteria willing, we should have a viable product within a year.
45 gallons is nice, but it’s not $2000 nice. Generally I think we agree that the 50-60 gallon range is ideal.
Patience guys… We’ve a legitimate reason to expect a solution is coming, and somewhat soon. Though an update from OP, perhaps touching base with his contact wouldn’t go unappreciated.
54 would be 20 additional gallons and would be an adequate size, however 59 or 60 would be even better.
Wish you could put something like a 45gal transfer tank in the bed & then have a cap over it totally concealing it as well as keeping it out of the weather
Problem is vapors, filling it and then using it
You mean like my 42 gal tank that fits perfectly behind the 5th wheel hitch and perfectly under my Diamondback cover?
In my 2013 I had a 60 gal transfer tank in the back covered with a BackFlip lid. I had to cut a hole in the lid so the filler neck stuck out. It worked out really well. The tank has a vent tube that you run out of the bed so the excess vapor doesn't stay in the bed. Whenever filling the tank I made sure to open the tailgate and part of the cover so the vapor can't pool in the bed.
Often I would park it in the garage and never could I smell the gas odor from the transfer tank. In fact the 2 gallon Rotopak on the back of my Jeep smelled more than the 60 gal transfer tank.
When I got the Tremor I moved the transfer tank to it and I am in the process of building a custom bed cover for it. I just haven't finished fabricating the back part yet.
The only problem I ever had with vapors was when the seal around the pump started to leak. You can see the white streaks on the tank in the photo. That smelled. But after putting a new seal on and fixing it properly no more problem.
2021 Tremor with transfer tank.
2013 with tank and BackFlip
Update: Transfer Flow said today they have purchased a 7.3L gas Tremor and are currently designing a larger fuel tank to replace the factory gas tank. However, it will not be released until sometime next year. The extended lead time is due to state & federal government approvals ... most importantly California's CARB certification process ... which will likely be the timeline controlling factor regarding the product release. When I inquired about the anticipated tank capacity in gallons, they said it is determined not necessarily on the room underneath the truck ... it may actually be controlled by the per vehicle government emissions restrictions regarding the gasoline evaporation rate out of the fuel tank vent line ... i.e. "shedding rate". Leave it to the environmental policy enforcement agencies of the US government to establish these minimal impact control policies regarding fossil fuel automotive emissions.
But if Transfer Flow intends to release a plug and play solution next year for an increased capacity gasoline tank underneath the truck ... I will now be delaying my ambitions and await that product release before moving forward with my "owner-designed" in-bed auxiliary gasoline tank solution.
I'd be perfectly content with a quicker, cheaper, product and an ethically sourced, multilingual, sticker that says:
No es legal para su uso en el Estado de California
Не законно для использования в штате Калифорния
Not legal for use in the State of California.
在加利福尼亚州使用不合法
غير قانوني للاستخدام في ولاية كاليفورنيا
Thank you for taking the time to follow-up. I have been checking for updates on this one daily.
Yes, thank you very much for the follow-up.
You have a cool setup, but we are putting on a truck cap of some kind, will have a fridge/freezer along with a solar generator that is dual hard wired into the truck and solar to power the fridge and other things.
Trying to set it up under a camper shell like that & then possible even sleeping in it in nasty weather conditions is more than I am willing to take on
That was a pretty slick tank setup on the 2013 F150. Unfortunately my F250 Tremor parks in the garage nightly ... so I do not want a transfer tank in the back of the truck. I am willing to wait for Transfer Flow's product release next year. But if it is less than 55 gallons, I will be looking at other options that get me at least 30 gallons of fuel under the cover in the back of my truck. ATI makes the tank and connecting hoses ... just need to purchase the pump and install it. Transfer Flow's selling point for me is the electronics they include with their auxiliary tanks that wire into the factory fuel tank level sensor wiring and transfer fuel as its needed. I don't have to flip any switch, remember to turn it off, or worry about my kids flipping the switch.
I put mine in the garage most days as well. Unless there is a leak, there is no smell of fumes. It is only going to outgass if the temp gets way up there. Having a transfer tank in the truck is the same as having an older car. It hasn't been until recently that the gas vapor from the tank is filtered. Old cars had a vented gas cap and that was it.
Transfer Flow's electronics sounds nice to me as well.
Following too. Thanks for the update.
Definitely watching this one!
I just submitted a request to ATI for a custom tank size. We will see if they respond. They have a standard size that almost works, but would be taller than the sides of the bed which I want to avoid. I'll let you guys know if they quote it.
Honestly, would likely do the Transfer-Flow replacement tank as well for maybe a 100ish gallons.
For you guys worried about a gas transfer tank, it it is set up correctly, you shouldn't have any issue. I have had a gas transfer tank set up on my Land Rover similar to the ATI systems for years without a single issue. Just buy a quality, weather-resistant low volume fuel pump and you should be good to go.
There is no way the TransferFlow tank will approach 100 gallons, try half that. What you want is an in-bed solution like others have discussed.
That is what I am saying. I hope the Transfer-Flow tank, in addition to a bed mounted tank approaches 100 gallons.
I'm roughly calculating the in-bed tank I am getting quoted from ATI at 42ish gallons. I'm hoping the Transfer-Flow tank falls into the 50-55 range.
Gotcha
I called today and the person I spoke with stated they were trying for an early 2022 release date, but they were still testing. I tried to get a size out of him and he said the diesel variant is 60 gallons and they were trying for 50 or more for the gas. Aluminized steel construction...
